Unable To Access Tmf From Home?
#16
Posted 13 May 2008 - 08:22 AM
#17
Posted 13 May 2008 - 09:11 AM
Ours has been showing all of that (and posts from the 9th May on the main page) the same as yours.... but this morning it's started working as normal!
Thanks TMF Doctors
I'm going to check when I get home tonight
#18
Posted 13 May 2008 - 02:35 PM
#19
Guest_iansmini_*
Posted 13 May 2008 - 04:01 PM
#20
Posted 13 May 2008 - 06:45 PM
Start > Run > cmd > nslookup www.theminiforum.co.uk
and post what you get back
#21
Posted 14 May 2008 - 07:02 AM
Can one of you having problems do the following...
Will try this tonight as is still not working
#22
Posted 15 May 2008 - 07:02 AM
*** Can't find server name for address 192.168.1.242: Non-existent domain
*** Default servers are not available
Server: UnKnown
Address: 192.168.1.242
Non-authoritative answer:
Address: 195.12.48.160
Aliases: www.theminiforum.co.uk
This came up when I tried the above
#23
Posted 15 May 2008 - 08:51 AM
There is a couple of work arounds though
First make sure it's not your own DNS cache.
start > run > cmd ipconfig /release ipconfig /flushdns ipconfig /renew
If this dose not work then add the ip to your hosts file.
start > run >%systemroot%\system32\drivers\etc\hosts
In the open with dialog box that will apear, select notepad
Add this line to the file.
89.149.242.87 www.theminiforum.co.uk
Save the file, reboot your pc and TMF will now work
If your using any other OS than windows, let me know.
Edited by Mort, 15 May 2008 - 08:58 AM.
#24
Posted 15 May 2008 - 09:15 AM
#25
Posted 15 May 2008 - 09:37 AM
Just had a quick peak at the TMF server to double check, no problems really jsut a couple that are worth fixing if you get time. (Or get sting hosting to)
ns1.stinghost.co.uk (89.149.242.87) allows recursive queries. Basicly anyone could use this NS and this can cause problems, but probaly not.
ns2.stinghost.co.uk (78.159.98.140) This won't respond at all, is it dead or dose it auto fail over to this ns if ns1 fails?
Edited by Mort, 15 May 2008 - 09:57 AM.
#26
Guest_iansmini_*
Posted 15 May 2008 - 10:38 AM
#27
Guest_iansmini_*
Posted 16 May 2008 - 10:28 AM
Is it because we are on a LAN and this is needed from the main operating computer were the wireless internet is hooked up?
#28
Posted 16 May 2008 - 10:41 AM
Right have done the suggestions that Mort gave but it will still not load at home!!!!!!!!!
Hi Ian,
It really depends on how your network is set up. If i have got the jist of how your network is set up then yes this will need to do this on the computer that servs the others. The hosts file change should "in theory, but this is windows we are talking about" work on your local machine.
I have a few other work arounds, please can you let me know what router your using? If the computer that servs the others the internet is connected to the interney via a modem then you will indeed need to update the hosts file on this. If it's connected via a router let me no the router make and model and i will talk you through how to set it up to use an alternative DNS.
#29
Posted 16 May 2008 - 10:42 AM
(also with Tiscali)
#30
Guest_iansmini_*
Posted 16 May 2008 - 10:49 AM
Oh forgot to mention when I did save the ip and web address to my hosts file it came up unable to save changes and then told me to do via a save as, but I did place it under the specified path.
Edited by iansmini, 16 May 2008 - 10:51 AM.
