Forced Cold Air Induction
#16
Posted 14 May 2008 - 08:14 PM
Thanks guys,
#17
Posted 02 June 2008 - 04:31 PM
#18
Posted 05 June 2008 - 09:51 PM
1605_thumb.jpg 12.92K 15 downloads
Induction Kit helper
Increases the performance of your car by upto 5%, fits with bracket behind the grill, the extendable aluminium tube takes air from the grill and increes air flow around the filter
£49.00 (inc VAT)
Seems kinda pricy for some fancy tubing u can probly get and do urself for cheaper. but i do admit this kit does look better, what does everyone think?
#19
Posted 05 June 2008 - 10:18 PM
Anyway heres the completed article,
Posted 05 June 2008 - 11:09 PM
#21
Posted 06 June 2008 - 07:31 AM
And how could they prove on an RR that it improved bhp? no RR I've ever used had a 60mph wind blowing through it!
#22
Posted 06 June 2008 - 09:43 AM
When on the road, put a boost gauge on it, I bet you don't see 2psi.
Hey mate, dont shoot the messanger! If it only smoothes out my flat spots i'll be happy.
#23
Posted 06 June 2008 - 10:05 AM
The thing is if you only want to reduce flat spots, this is a very hit and miss approach. Assuming that you do improve the volume of air going into the carb (a big assumption) then this will only help if your mixture was rich to start with. If the flat spots are being caused by a lean mixture it'll be worse.
At a guess, if you have non-standard induction and exhaust but a standsrd dizzy, the chances are that the timing is the main cause of any flat spots. although looking at the photos it all looks standard.
The other thing I notice is that the air box has holes drilled in it, to get any benefit from a cold air pipe you'll need to block these up. I appologise if you have already mentioned that you plan to do this.
#24
Posted 06 June 2008 - 10:19 AM
Thanks again,
#25
Posted 06 June 2008 - 10:44 AM
also, the holes in the airbox together will more than likely greater the hole where the filter goes so air will opt to go through them instead. If your having flat spots etc its prob due to what you have done with the airbox. Removing the restrictions and allowing better airflow will need slight fuel adjustment.
try fitting a standard airbox unmolested on. if it solves the issue then just leave it or you can try giving the fuel 1/8th turn richer.
#26
Posted 06 June 2008 - 10:56 AM
#27
Posted 06 June 2008 - 11:10 AM
Please note that i am not trying to be awkward and i appreciate the effort and the time it is taking people to reply. I am not hiding the fact i know little about the topic in question and i am sure you are all plenty more knowledgable than me.
#28
Posted 06 June 2008 - 09:43 PM
In my opinion its just a big waste of cash/time/effort, if there were any gains to be had from it then surely everyone would be using them...
#29
Posted 07 June 2008 - 05:45 PM
but anyway, even if its not too functional, i would think that would be some extra marks for the engine bay as well! personally i likes the look and layout of your engine bay, MrMini.
#30
Posted 07 June 2008 - 07:19 PM
well juz let the testing to tell us about the actual result, so i'll look forward to the result later ya!
Thanks mate.
