Parcel Shelf Speakers
Posted 26 May 2005 - 12:22 PM
thanks
Posted 26 May 2005 - 12:24 PM
Posted 26 May 2005 - 12:47 PM
Posted 26 May 2005 - 01:25 PM
If it does, then use it as a template and cut a parcel shelf out of MDF or Plywood. CUt your speaker holes in this wood, then use this as a base to put the speakers onto. It will basically be a mount between the metal shelf and the speakers.
Its just to stop the rattle and give a dense surface for the speakers to sit on...
Ive got my 6X9s under my rear bench. I prefer them there as they are in a sealed enclosure and are VERY bassy.
<|Ben|>
<|Ben|>
Posted 26 May 2005 - 01:44 PM
If you have a sub in the boot then I wouldnt' recommend 6*9's in the rear shelve.
If you want a decent compromise between SQ and SPL then I would say go for 6*9's. They will provide you with a good sounding full range speaker in the rear.
If you want pure SQ I would put 6 1/2" Components in the rear.
And for the $$ of a low end set of comps you can get a mid end set of 6*9s.
So if you're looking for some decent sound without breaking the bank, then 6*9's should sound fine in the rear of your mini. The 6*9's will provide you with more base also, as they can move more air.
*Dislcalimer: I am not an expert, and the above is purely based on my experience and information learned and collected.
lost.
Posted 26 May 2005 - 04:16 PM
Im gunna try and fit a sub on the rear parcel shelf but thats it as Im trying to get as much bass and clarity with as little weight as possible.
Posted 26 May 2005 - 07:32 PM
SPL= 6x9's and on the parcelshelf there not even much good at this as the metal shelf starts to rattle.
Wouldn't go with comps in the back for the price diff over coaxils as the tweeter will be mounted that far away from the midbass speaker that they can cause probs.
Posted 26 May 2005 - 10:24 PM
Posted 27 May 2005 - 07:29 AM
Yeh, even better, one for the TMF_CD me thinks, and also if someone would like to do a template of the rear parcel shelf ??them box's for the 6x9's look mint any chance u can send me a template so i can make some thay look ace
I put a 10 Inch sub into someones, Mini big hole in the middle with crossovers from left and right channels.
Posted 27 May 2005 - 06:56 PM
Hopefully this will give me a light weight base for a small front mounted install.
Posted 27 May 2005 - 08:35 PM
Posted 28 May 2005 - 12:44 AM
ta
pete
Posted 28 May 2005 - 01:19 PM
covered in carbon fibre look stuff...
with speakers......£40
Posted 28 May 2005 - 01:41 PM
Ill post the templates for the small boxes once I get my scanner up and running
Posted 28 May 2005 - 04:38 PM
