10x8 or somethin like that
38 replies to this topic
#31 Oldskoolbaby
Oldskoolbaby
  • 1,361 posts
Posted 27 May 2005 - 10:46 PM
No probs, If you get any probs just PM me. Good luck with those wheels though mate. :cool:
#32 Equinox96
Equinox96
    Just On Tickover
  • 8 posts
Posted 28 May 2005 - 10:23 PM
Just a quick "hi" message really. I am also looking into getting some wide 10"s. I was going to go for the brakes conversion that minispeed offer but will most likely go with something like KADS for callipers. The sound of word "six-pot" is certainly pleasing but I will most likely go for 4-pot. Would people agree that 4-pot is enough for road use (although fairly manic road use from time to time)?
#33 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 28 May 2005 - 11:14 PM
the kad 6 post are race only, they dont have dust sheilds wo will need rebuilding regularily... The 4 pots are perfectly adequate at handling anything but the most serious of petrol heads can throw at them , and that's in non vented form. As for the wheel sizes...
The mini docs are seeking the tyre manufacturers advice..
#34 marksmini
marksmini
  • 49,441 posts
  • Name: Mark
Posted 28 May 2005 - 11:24 PM
im closeing this topic until we have had a definitive answer from the Tyre manufactuurers, as we are a little concerned about the advice which has been provided. On behalf of the mini doc's Bankxi has been PM'ed voicing our concerns,
it can be re opened at a later date :cheese:
#35 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 07 June 2005 - 02:22 PM
Here's the deal, and this is from the horses mouth ( Yokohama and Falken )
Yoko A008 165/70x10 Rim Width 4.0" to 5.5"
Yoko A032R 165/70x10 Rim Width 4.0" to 5.5"
Yoko A048R 165/55x12 Rim Width 4.5" to 6.0"
Yoko A539 165/60x12 Rim Width 4.5" to 6.0"
Yoko A048R 175/50x13 Rim Width 5.0" to 6.0"
Yoko A539 175/50x13 Rim Width 5.0" to 6.0"
Falken SN-807 145/80R10 Rim Width 3.50" to 5.00"
Falken SN-807 145/80R12 Rim Width 3.50" to 5.00"
Falken SN-828 145/70R12 Rim Width 3.50" to 5.00"
Falken FK-07E 165/70R10 Rim Width 4.00" to 5.50"
Falken FK-07U 165/70R12 Rim Width 4.00" to 5.50"
Falken FK-06G 165/60R12 Rim Width 4.50" to 6.00"
#36 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 07 June 2005 - 02:56 PM
so no tyres for more than 6 inch wide
well done guess works can it be in FAQ
#37 Pavel
Pavel
  • 2,451 posts
Posted 07 June 2005 - 03:09 PM
As has been said, you COULD fit those tyres to a 7" or even 8" wheel, but equally you COULD have a 1380 turbo mini with drum brakes. It's your life at stake...
Basically don't do it. 6.5 is about as stretched out as you need on a road car, and if you want to do racing there are racing tyres which will fit on 6.5 as well so you get the best of both worlds.
#38 Oldskoolbaby
Oldskoolbaby
  • 1,361 posts
Posted 07 June 2005 - 08:28 PM
No offence but I personally think thats a load of rubbish really. The fact that they dont recommend it for 6x10s says it all. People have been using them for years.
I completely agree with you for checking with manufactures but I dont mean to be arragant or rude but its like putting a warning on a mobile and saying its gunna fry your brain when you use it. We would still use it cause we all know its just the makers covering themselves.
Its like when I plumb a boiler in at work. The average person doesnt realise that I have to pressure test the pipework to over 3 times the normal working pressure but I turn it down just to cover myself. Its exactly the same for the tyre manufacturers, they are never going to tell you what the real limits are.
Im have only ever spoke about what Ive only ever seen and experianced and I would honestly never bu115h1t anyone when it comes to safety. If you are wary Id suggest sticking with Guessworks advise.
Thanks for clearing that up though Guessworks. It also gave me some info on the 12 inch wheels. Did you get any info on the 13 inchers as I often see tem stretched on to those.
Cheers mate
#39 bluebottle
bluebottle
  • 844 posts
Posted 07 June 2005 - 09:21 PM
i've been running yoko a008's on 7" MB split rims for around 6 years now, with no problems whatsoever.
i know that according to the manufacturer i shouldn't, but if you fancy going down that route (off your own back), i would say you could with an element of confidence.
