Fuel gauge
Posted 19 February 2004 - 04:24 PM
i spose it not a major problem because i keep topped up on fuel but it can be misleading, e.g. traveling to mini 45, i may have plenty of fuel left but the gauge will read empty :sad:
does that happen to other people or is that a mini characteristic that i dont know about?
Posted 19 February 2004 - 09:59 PM
Best thing to do is to get another send, they are easy to fit and takes about 30 seconds...
Posted 20 February 2004 - 03:13 AM
thanks,
pEaCE
Dom
Posted 20 February 2004 - 10:45 AM
Posted 20 February 2004 - 07:14 PM
If you look at the side of the tank in the boot, you'll see 2 wires going to a round thing on the side of it.
Unplug the wires.
With a big ish screw driver and a hammer tap the lugs on the ring around the edge of the round thing until it undoes. This ring is the bit that holds the sender in.
Once undone, the sender can then be taken out of the tank through the hole.
Easy as that!!
When you re-fit it in the reverse of how you took it out, dont forget to put the rubber seal bag in and make sure you knock the ring round as far as it will go, so you don't loose fuel all over your boot when you next fill it up.
This job should take about 5 mins at the most
Posted 20 February 2004 - 08:07 PM
Posted 20 February 2004 - 10:47 PM
Posted 21 February 2004 - 08:18 AM
You sure you put the wires on the right way round? If they are on the wrong way it reads full all the time.
Posted 21 February 2004 - 05:05 PM
Posted 21 February 2004 - 05:32 PM
Here's a quick tip if you think your fuel gauge isn't reading correctly. I suspected that my fuel sending unit was going haywire, and everybody I asked said "Be sure to check the gauge itself to make sure it's working!"
It turns out that the first and easiest test is visual. Items you will need:
1) Fuel tank
2) Flashlight
Remove your fuel cap.
Shine flashlight into tank.
Locate float of fuel sending unit.
Float should be bobbing nicely at the surface of your fuel.
If tank is 3/4 full and the float is sitting on the bottom of the fuel tank, your fuel sending unit is hosed.
*Note* This is also a good way of checking your fuel level before popping off the fuel sending unit, and opening a 2-inch hole in your tank. If the float is riding at the surface of the fuel, it's time to suspect the gauge or the electrical connection between the sending unit and the gauge.
not written by me off another site
Posted 28 February 2004 - 07:50 AM
where do you get the wires from?
Posted 29 February 2004 - 10:11 AM
hope thats what you meant,
pEaCE
Dom
Posted 29 February 2004 - 11:03 PM
Posted 26 March 2004 - 02:18 PM
Posted 26 March 2004 - 04:58 PM
Then connect the wires back on the sender. If there is only one you will need to add an earth wire to it. Then simply bend the rod that the float is on till it reads where you want it to.
Even if you fit a new sender you can still have poor readings. The gauge is ONLY an indictor and therefore its accurcy is no wonderful.
Siggy
