one slight problem the ignition light and low oil pressure light are permanently on even with ignition switch off and the only way to stop the engine is to pull the coil HT lead off
(dunno if u already sorted)
You wired the lucas coil to the fuse box? i've got the same coil, this issue happened to me when connected the coil to the wrong fuse, went in short circuit.
just wired + to the upper fuse, and it worked fine.
Edited by jaydee, 23 February 2009 - 11:37 AM.
