Bungles Cooper
#91
Posted 08 February 2009 - 05:27 PM
#92
Posted 08 February 2009 - 06:07 PM
*takes phone off the hook*
funny you should say that
i did wonder how you were fixed for time on the 21st and if you want to stay the weekend we are off slot car racing on the sunday you could tag along
#93
Posted 08 February 2009 - 06:40 PM
yep that should be fine mate
#94
Posted 08 February 2009 - 07:35 PM
#95
Posted 09 February 2009 - 10:40 PM
#96
Posted 09 February 2009 - 10:48 PM
so at the moment i have just replaced like for like
#97
Posted 09 February 2009 - 11:29 PM
i have asked on so many forums and everyone says something different
Any problems yet?
#98
Posted 09 February 2009 - 11:34 PM
although with it sitting on the floor next to the car it might not help
#99
Posted 10 February 2009 - 10:17 AM
Using this info look at the following page to cross reference from one to the other. You will see that a 35A glass fuse is about equal to a 15A blade fuse (erring on the side of caution initially - you may find a 20A blade is needed).
http://www.vehicle-w...fuses/fuses.php
#100
Posted 21 February 2009 - 07:35 PM
one slight problem the ignition light and low oil pressure light are permanently on even with ignition switch off and the only way to stop the engine is to pull the coil HT lead off
but the engine runs and is roughly timed and fuelled
brakes tomorrow
#101
Posted 22 February 2009 - 07:36 PM
it would of been easy to replace if the engine wasn't fitted
still got my charge and low oil pressure lights on with ignition off
*shouts* crocks
#102
Posted 22 February 2009 - 07:45 PM
Also, there *should* be a little access hole in the inner wing on the N/S that allows you to tighten up that brake pipe union, it might just need nipping up?
#103
Posted 23 February 2009 - 09:36 AM
#104
Posted 23 February 2009 - 10:34 AM
its tight already so looks like a new end and union is needed, im now moving to live with bungle as hes personal mechanic
the only problem is i act as a e-number for william
#105
Posted 23 February 2009 - 10:45 AM
brakes tomorrow
Looks very very nice mate!
