your not going for hugh power so you dont need too low a compression ratio.
personally i would take a goodish condition mg metro engine get something like a stage 2 head with the standard chamber sizes.
and get the mirage manifolds.
while the engine is out put a molychromed 4 pin diff on it.
basicly that engine there. will give you slightly lower fuel economy then the standard engine if you keep off the boost but its marginal.
and 120-150 at the fly if you turn up the boost, i suggest you put an intercooler on it. improves power while enableing you to keep the boost down.
and youll have lots of money still left in your hand.
if you source all your bits carefully you could proably do it for 800 or even less.
Edited by flyingears2002, 14 June 2008 - 01:17 PM.
