Supercharger
#16
Posted 14 June 2008 - 02:46 PM
I was thinking getting SC drops and the X-Pin diff also a mappable ignition would help wouldnt it?
Would you keep the cam standard as well?
What kind of inter cooler would be good to use?
You say goodish bottom end, is the MG metro standard not up to the job?
Appreciate the help.
Rhys
#17
Posted 14 June 2008 - 04:58 PM
but i mean if you want to go beyond 120bhp a center strap and some bottom end work and stright cut drops and a cross pin diff.
as for the intercooler get the most efficent one you can find.
Edited by flyingears2002, 14 June 2008 - 05:01 PM.
#18
Posted 14 June 2008 - 05:45 PM
Will it get me the power i want?
Rhys
#19
Posted 14 June 2008 - 05:55 PM
I would use the NA MG Metro cam or the Kent 266 both should be good for your application. As suggested i'd install a twin pin diff whatever spec your planning on going for. For peace of mind i'd probably stretch to SC drop gears to, though some people run the standard ones up to around the 120hp mark, with the torque of the charger i'd add them to your shopping list. A properly built standard bottom end will be fine, as said, it's revs that kill the bottom end. But you'll not need to rev it hard with the charger fitted.
If it's a suck through install, you can't use an intercooler.
If your interested in a head have a look on my website, i think you'll find the prices very competetive. I'm currently doing a head for a customer who is aiming for the same kind of power as you & is using the Eaton charger. I'm using 36mm inlets with 30mm exhausts, fully ported, bulletnosed bronze guides etc. Basically i can tailor it to your application, so whatever you need.
Phil.
#20
Posted 14 June 2008 - 06:17 PM
On a well built engine, properly set up with a decent cam & head you'll be looking around 125-130hp.
#21
Posted 14 June 2008 - 06:20 PM
Rhys
#22
Posted 14 June 2008 - 06:30 PM
For your application the head doesn't need to be OTT, either the fast road unleaded, or the fast road/trackday heads i do can be tailored to suit your engine spec. Either one will be more than enough for the power you want & more.
#23
Posted 14 June 2008 - 06:52 PM
Rhys
#24
Posted 14 June 2008 - 07:01 PM
Where would you recommend getting one from? Dont suppose you could link it for me do you?
Rhys
What, the head ? Have a look at my sig.
#25
Posted 14 June 2008 - 07:11 PM
Rhys
#26
Posted 14 June 2008 - 07:13 PM
Rhys
#27
Posted 14 June 2008 - 07:28 PM
#28
Posted 14 June 2008 - 07:45 PM
Rhys
#29
Posted 15 June 2008 - 08:46 AM
turbo-mini.com cylinder heads
Phil.
Edited by Turbo Phil, 15 June 2008 - 08:47 AM.
#30
Posted 15 June 2008 - 04:39 PM
and that was a standard 1275 with the head combuston chambers reworked to lower the compression to 8/1
no fancy heads cams etc
was easy to drive as normal or just keeped going when you put you foot down
steady driving gave 35mpg or about 9mpg when flat out around the ring
loads of fun around the nurburgring in 2006
is footage on youtube
