Taking flywheel off
28 replies to this topic
#1 Jammy
Jammy
  • 25,397 posts
Posted 06 June 2005 - 09:16 PM
Stripping down the 850 this evening (had to go to Halfords to get flywheel puller and socket for the flywheel nut (the one that goes on the crank)), I've put the flywheel puller over the thrust plate (I think its called that) following the Haynes manual, started to tighten the bolt that goes through the middle, and its become really really tight, and the flywheel puller plate isn't even touching the thrust plate yet, is there something I've missed??
#2 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
  • Local Club: Blacktop Bombers
Posted 06 June 2005 - 09:20 PM
Have you taken the big bolt out that holds the flywheel on and the big key washer from underneath?
#3 Jammy
Jammy
  • 25,397 posts
Posted 06 June 2005 - 09:27 PM
Yea. (Would I still be able to get the centre bolt of the flywheel puller in if that bolt was still in?!)
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 06 June 2005 - 09:40 PM
You don't want the puller to be touching the flywheel, have you put the thrust block in place as it looks like the centre bolt has gone it way too far. Have another look at the instructions and try again.
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 06 June 2005 - 09:41 PM
looking at the picture you should have a big thick washer that the main bolt presses into and onto the crank, the puller at the moment is not pulling the flywheel, it looks like you've screwed the bolt into the crank, which unfortunately could mean curtains for the crank...
#6 Jammy
Jammy
  • 25,397 posts
Posted 06 June 2005 - 09:53 PM
Ah McBuggery! I think I know what your talking about. The problem was that the flywheel puller I got didn't have any instructions, so I was simply going off what the Haynes manual was telling me, I did have another couple of bits, along with another set of three bolts (I'm guessing metric?!). One sec and I'll get a pic of the bits I have left.....
#7 Pavel
Pavel
  • 2,451 posts
Posted 06 June 2005 - 09:55 PM
Could be the same problem as the metro engine i got. Due to exposure to the elements and probably mis-use, the flywheel was effectively fused to the crank and would not come off by any means... 1.5m breaker bar on puller didn't help, heating the flywheel and cooling the crank till flywheel was red hot didn't help... hammers didn't help... engine was scrapped (after cam extraction :lol:)
#8 Jammy
Jammy
  • 25,397 posts
Posted 06 June 2005 - 09:59 PM
I dunno, most things have come off the engine pretty easily upto now....
by the way, its the 'Laser Mini Fly Wheel (2 words?!) Puller' I'm pretty sure they shouldn't spell flywheel as two words but ah well!!
piccie:
#9 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 06 June 2005 - 10:10 PM
Yup, that thick black round thing is the thrust block which stops you chewing up the end of the crank.
Take the centre bolt out of the puller, hold the puller in place and tighten the three outer bolts evenly and when I say evenly I mean they must all be threaded in the same amount so that you get a straight pull (make sure you use the right set of bolts for your flywheel, one set is verto and one is not and you can wreck a flywheel using the wrong ones. Also make sure you put the thick washers under the bolt heads or you will break the puller) . Now pull the puller up tight onto the bolt heads and hold the thrust block in the end of the crank while threading in the centre bolt. When it is touching the thrust block it is ready to use. Make sure the flywheel keyway is horizontal (whichever way up the engine is standing it must be horizontal) and turn in the bolt a few flats and the wheel will drop off. Have something nice to catch the wheel on (like an old cushion or something) as standard wheels are very heavy and it will surprise you how heavy it is when it drops.
#10 Jammy
Jammy
  • 25,397 posts
Posted 06 June 2005 - 10:15 PM
Lol, new crank on order!! Lol, ah well, I live and learn!
Thanks Dan, Bluemini, Pavel and Guessworks, am pretty sure I can now get the flywheel off without ruining anymore of the engine!! Just hope that crank was a rare or really decent one!!
Just one question, I'm guessing the crank keyway is the slot that goes through the middle of crank?
#11 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 06 June 2005 - 10:16 PM
Yes it is.
#12 Jammy
Jammy
  • 25,397 posts
Posted 06 June 2005 - 10:19 PM
Cool, will let you know how I get on tomorrow/maybe Wednesday night.
#13 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 06 June 2005 - 10:27 PM
iv got exacltly the same one and was using it this morning! your righjt about the other goldish looking bolts, that are indeed a different thread type! have u got a way of locking the flywheel at all?
#14 Jammy
Jammy
  • 25,397 posts
Posted 06 June 2005 - 10:31 PM
LOl, yea, a BF screwdriver! Have you got a better method?
#15 Madmax
Madmax
  • 2,638 posts
  • Local Club: Grimsby & Louth MOC
Posted 06 June 2005 - 10:39 PM
nope LOL thats exactly the method we use
