Taking flywheel off
#16
Posted 07 June 2005 - 09:01 AM
#17
Posted 07 June 2005 - 09:59 AM
#18
Posted 07 June 2005 - 07:54 PM
But I got the flywheel off (not before breaking the plate that goes over the flywheel!!) Couple of questions, theres three like plates on the clutch side, is the one the block side of the flywheel the clutch, then theres the flywheel then is it the thrust plate?!!
Well am now going to have to use the 998 block from the Clubby on the gearbox from the 850! I'm sure I have read before that its possible to take a box from a A series engine and put it on a A+ block? I just have to use the correct idler? Is this right?
Sorry for taking this off topic, but I thought my original question has already been answered previously, so no harm done!!
#19
Posted 07 June 2005 - 08:09 PM
How on earth did you manage to scrap a block removing the crank pulley? I didn't know hammers were made that big! The pulley should come off really easily.
You can buy flywheel locking tools for about twelve notes if you know where from, that's what mine cost.
#20
Posted 07 June 2005 - 08:14 PM
Spose I should of taken off the pulley before the flywheel!!
#21
Posted 07 June 2005 - 08:23 PM
I know, I'm special!!!
If you've got the gearbox off you can lock the crank really easily with a big 'ol lump o wood. Sitck it between the crank and the crank case and that's it, locked up tight. Or if the gearbox is still on you can use a flywheel locker as described above or (my personal favourite for removing pulleys) an oil filter strap wrench around the pulley, the more you try to turn it the tighter it holds. They even make wrenches designed for use like this from lengths of vee belt.
#22
Posted 07 June 2005 - 08:27 PM
tip, If you ever need to brace something use a piece of wood ( that breaks before the metal ! )
**edit**
Looks like me and Dan are on the been there done that bus again!
Edited by GuessWorks, 07 June 2005 - 08:29 PM.
#23
Posted 07 June 2005 - 09:11 PM
ARe you able to answer one more question for me guessworks? The gearbox, can I use the A series gearbox on the 998 auto A+ block?
#24
Posted 07 June 2005 - 09:20 PM
#25
Posted 07 June 2005 - 09:37 PM
Am going to start my own project thread in a bit!
#26
Posted 07 June 2005 - 11:09 PM
and DONT RUSH IT
#27
Posted 08 June 2005 - 09:21 AM
#28
Posted 08 June 2005 - 09:32 AM
Also, would you post if I paid?
#29
Posted 08 June 2005 - 10:14 AM
or... if the crank etc is ok in your 998 auto, you may just need the block !
Can post but will need to sort out a courier... and don't know how much it would cost
Edited by GuessWorks, 08 June 2005 - 10:15 AM.
