Exhaust Heat Wrap, Is It Worth It?
#16
Posted 04 September 2008 - 12:02 PM
#17
Posted 04 September 2008 - 01:16 PM
There are other things that can be blamed on the exahust wrap, like rust. But as said before, there is a good and bad balance or compromise to be made with every mod.
I'd still use the wrap whenever possible.
One thing I have not noticed in any exahust kits for minis is a small flexi-pipe.
I have always included one in every install regardless of the car, and this is the way it is in the mini, right after the lcb.
#18
Posted 04 September 2008 - 09:38 PM
#19
Posted 05 September 2008 - 03:05 AM
#20
Posted 05 September 2008 - 08:00 AM
I think manifolds will crack eventually but this could be due to 'uncontrolled' engine movement (i.e faulty steadies or bushes), that plus the high temperatures they withstand will make them crack.
The manifold in question was only 9 months old and the car has both gearbox steadies fitted, so there isn`t any engine movement. These companys do know the high temperatures the manifolds get to, But the exhaust wrap puts even more heat in to them eventually warping and/or cracking them. so i won`t be using it on and A series mini anyway.
Edited by mini_kel, 05 September 2008 - 08:01 AM.
#21
Posted 05 September 2008 - 06:41 PM
#22
Posted 13 July 2009 - 10:41 AM
#23
Posted 14 July 2009 - 07:29 PM
#24
Posted 12 September 2010 - 04:58 PM
Sorry to drag up an old thread but I was just wondering if I could use some exhaust wrap to reduce the heat in the cabin? The area around my gearstick and handbrake gaiter gets quite warm, could I get away with wrapping this section of the exhaust to reduce the heat? It's a mild steel Maniflow Cooper FreeFlow system by the way
Most modern cars use aluminum heat shields for this. The wrap probably won't be the best since it will be hard to fit because it's in relatively thin strips for that purpose. You could try getting a large heat shield from any used parts source and then bending/cutting to fit the mini. This would probably be the cheapest way or you can just get a universal product for that purpose like these Heat Shields
#25
Posted 12 September 2010 - 09:21 PM
Edited by The Reverand, 12 September 2010 - 09:22 PM.
