Hoot. The Leyland Makeover
#121
Posted 24 May 2012 - 08:54 AM
#122
Posted 24 May 2012 - 10:18 AM
Sam.
#123
Posted 06 June 2012 - 12:14 PM
I have a complete rear brake setup on the way with the one inch drums so I can get rid of these horrid spacers. the car shakes like grandpa jones.
I have just about enough saved for the front disc conversion from seven.
The only issue I'm having now is: when cold the throttle cable is smooth as silk. while I drive it is smooth as silk but once I sit in traffic or after it sits the cable gets tight and choppy. So, it has something to do with heat. It is not very close to the header... maybe two or three inches. I'm thinking of wrapping it in aluminum foil to see if it will disapate the heat. if that works I'll put some type of wrap on it.
If I pullup on the cable at the carbs the linkage seems smooth.
any suggestions?
Ive been busy working on my cabby. had to touch up a section or two of paint. also had the mini out for a drive around the back yard.
Edited by bigcaddy, 06 June 2012 - 12:22 PM.
#124
Posted 27 June 2012 - 05:09 PM
I have all new rear parts as well but drums.
#125
Posted 05 July 2012 - 02:37 PM
Took a little pumping to get them bled but they work great so far.
I also got rid of the Ghetto wheel spacers.
Front brake setup should be here soon.
I plan to remove the rear subframe this winter and redo all of it so I'll pass on painting the backing plates until then.
#126
Posted 10 July 2012 - 01:53 PM
I also made up a stainless steel wrap for my radiator since mine has been gone since I've owned it. They want $85.00 for one of these. fug that.
#127
Posted 11 July 2012 - 12:29 PM
I also ordered new tie rod ends since mine were all bitched up from the air chisel. Bastard getting the one out.
I got all the lines re bled and the pedel feels perfect. I have to move the fleet of cars to get this one out. I have a two hour drive in the mini this weekend so I'm trying to get it ready. It has about 30 miles on the fresh motor so I imagine what ever will happen should have happened. I'm hoping for the best with my throttle cable. Seems good now. I used a VW golf throttle cable and it doesn't bind at all. After trying two brand new mini cables. The VW cable is almost twice the thickness not to mention I have a few of them laying around.
#128
Posted 17 July 2012 - 12:46 PM
I'm thinking an oil cooler is next to help with the longer highway drives.
#129
Posted 17 July 2012 - 08:06 PM
#130
Posted 19 July 2012 - 02:44 PM
We have several places that ship from MiniSpares. My differential showed up from MiniSpares in three days. Blew my mind.
THere are plenty of places in California and New York for parts.
We have a lot of Triumph fans around so I usually tag along with them.. The Mini always gets the most attention.
#131
Posted 19 July 2012 - 02:46 PM
I'm leaning towards some 13" wheels. can anyone suggest a proper offset. I don't mind getting larger flares and trimming the fenders (wings)
#132
Posted 19 July 2012 - 07:34 PM
#133
Posted 19 July 2012 - 07:41 PM
On a different note. I"m thinking some different wheels.
i would keep the car on 10" wheels personally .... for 2 reasons
1. mini's drive much better on 10" wheels
2. 13" wheels ruin the front wheel bearings and you will be replacing the bearings on a fairly regular basis.
#134
Posted 26 July 2012 - 02:46 PM
#135
Posted 03 December 2012 - 09:33 PM
Anyways... Since I can't put of a wanted ad I'd like to ask for your assistance in locating stuff.
I need a Hella 160 Chrome driving light. we don't have the chrome ones used in the states.
