T's Vtec
#16
Posted 24 June 2010 - 11:31 PM
Have you guys had any experience with Laminova intercoolers? My local fab guy has recommended it.
#17
Posted 24 June 2010 - 11:41 PM
Edited by miniQ, 24 June 2010 - 11:53 PM.
#18
Posted 25 June 2010 - 09:33 AM
I hope I can source some custom work here in Oz as everything so far has come from across the waters. PWR intercoolers are a nice thing however I am being promised that laminova setups are far more superior and is the way to go.
#19
Posted 25 June 2010 - 01:43 PM
I would have went with a water to air if it were'nt for the shock and awe factor that I needed. They are nice units and well done. There are many people in the mini world for the most part new minis and a few Subarus that I know of using the Laminova intercooler with good results. Thats the one main problem with using a turbo in these rear engined cars is where to put the intercooler. My original plan was to run the pipes from the front through the original firewall then on the floorboard of the passenger side and back. But I found that the front engine bay was too confined to make it work properly.
The Full Race stuff is very nice and very well made. I originally had bought there manifold for my setup. But, it fouled the top bar and couldnt use it. This was there RSX Kseries ProStreet sidewinder version though. But very nice stuff.
Edited by PhotoguyUSA, 25 June 2010 - 01:46 PM.
#20
Posted 25 June 2010 - 10:55 PM
#21
Posted 26 June 2010 - 12:39 AM
There are 3 clear pictures BUT looking at your kit it seems you may have different/newer trailing arms :/ - Also if you dont mind me asking what dry-sump setup you plan on running
Edited by miniQ, 26 June 2010 - 12:41 AM.
#22
Posted 26 June 2010 - 09:49 AM
I had ordered a morosso pan and peterson pump. That may be no longer. Here is a picture that was sent to me to get a visual of this product.
I may look into Daily Engineering's dry-sump set-up for the K20. From what I have seen, I believe they mount the pump on the driveshaft side as they run these in longitudinally engine mounted cars.
Posted 27 June 2010 - 04:57 PM
Edited by miniQ, 27 June 2010 - 05:02 PM.
#24
Posted 27 June 2010 - 05:34 PM
#25
Posted 29 June 2010 - 01:36 PM
What state are you in? I am in Sydney.
Not sure what type of work you do or if you have connections for parts, but I am more than willing to help with that. I am a dealer of Rocket Industries also another mini place with the cheapest parts for Minis that I know of is Kar Craft.
I am hoping to get a kit of 'any' kind for the mini registered in NSW. I have some more research to do, but it looks like my only option is the Pro-Motive kit.
Good luck and I look forward to the rest of the build.
Con
#26
Posted 30 June 2010 - 01:44 AM
Lyle, you are right that there is no way this will fit... looking at alternatives ATM.
#27
Posted 30 June 2010 - 04:46 AM
Can't wait to see how this goes. Have you heard of anyone getting this sort of kit registered?
#28
Posted 30 June 2010 - 02:27 PM
#29
Posted 09 July 2010 - 09:08 AM
sideengine.jpg 96.51K
88 downloads...this appears to be mounted higher (above where block meets sump). A shot more at eye level with the crank would be perfect!
Also I will be running an electric water pump so there may be some room upwards due to not having the OEM water pump pulley.
Posted 09 July 2010 - 09:38 AM
P1150228.JPG 2.01MB
23 downloads While we are looking at the lower rear end of the kit here are a couple more:
I have noticed my rear anti-roll bar is different from Andy's
P1150225.JPG 1.92MB
98 downloads
P1150236.JPG 1.9MB
55 downloads
