Chloe '99 Cooper - 1380Cc
#46
Posted 04 February 2013 - 04:33 PM
#47
Posted 25 February 2013 - 05:46 PM
#48
Posted 07 March 2013 - 01:27 PM
Nodiz Pro Controller
Trigger Wheel
Brackets
Crank Sensor
Just need to get a coil pack now and im away.
#49
Posted 07 March 2013 - 03:24 PM
Does it simply replace the current injection system or do you have to revert to a carb?
#50
Posted 07 March 2013 - 03:55 PM
Interested to see how you get on with this.
Im already converted to HIF 44 Carb, so should be simple.
#51
Posted 07 March 2013 - 04:20 PM
Hope the setup goes well. Should give you some good performance
#52
Posted 07 March 2013 - 04:36 PM
#53
Posted 17 April 2013 - 04:58 PM
Started out all i had done was bonnet off and alternator removed...which i found to be cracked
Stripped out the cooling system and all the connections for the carb, manifold is being a ballbag!
Looking a bit more roomy now
left her ready for more work tomorrow
#54
Posted 18 May 2013 - 07:32 AM
#55
Posted 07 October 2013 - 07:14 PM
Progress finally.
So since last update I had moved to a new workshop in my camp, where I had all my tools, engine hoist and power.
As well as my rally cars in progress.
Then we had a visitor who has since been stripped ready for a 16v conversion...
Lifted the engine and gave it a good degrease and clean.
Started to fit my NODIZ components although I lost access to the workshop and had to move back to my lock up garage, not the best of timings when the engine and subframe was off but hey...
Back at my garage now with the engine still out. fitted my dizzy hole bung, timing wheel and sensor, time to start thinking about dropping the engine back in and reassembling...
#56
Posted 18 February 2014 - 06:38 PM
Progress!!!
Pushed her up onto the drive so I can do some work while the kids sleep.
Old snapped brake pipe off, taking it with the new one to bend in the morning.
#57
Posted 18 February 2014 - 06:58 PM
#58
Posted 18 February 2014 - 07:33 PM
New pipe...
Hoses and shiz..
#59
Posted 19 February 2014 - 01:48 PM
New pipe and Goodridge hoses fitted today...
#60
Posted 22 February 2014 - 01:59 PM
Tidied up the garage and set about getting the engine back in...
Realised I had forgotten to remove the dizzy drive...
So took care of that and with my little helper Lucas, lined the mini up with the garage and hooked up my crane...
Swapped out my engine brackets...
Took off the bonnet and realised I cant put the engine in with the driveshafts still fitted, so its on hold again till Monday.
No room in the garage with the crane set up so she is all wrapped up in the A Series Spares cover and a shitty waterproof one over the top...
Just wish it wasn't illegal to do anything other than go to Church on a Sunday in Germany!
