1984 Austin Mini City Cylinder Head Change
roundnose
23 replies to this topic
#16 MINIMAD555
MINIMAD555
  • 67 posts
  • Local Club: Medievil Minis
Posted 29 August 2013 - 10:15 PM
Good job, it always amazes me how much carbon builds up in an a series engine, I have took other cars apart and nothing compares to the a series for it, I took a k series apart and it was really clean, must be to do with the combustion chamber shape or su carb.
yea always get quite a bit of carbon build up in an a series, this engine has done nearly 85000 miles, but good job it was not running to rich
#17 1984mini25
1984mini25
  • 8,850 posts
Posted 29 August 2013 - 10:30 PM
everything nearly got the engine running but did not last long till the bypass cheap crappy hose started to leak, and found a pin hole in it :(
Those 'easy fit' bypass hoses are a waste of time and money, I've always used a section of half inch heater hose instead and never had any problems.
#18 rally515
rally515
  • 3,848 posts
Posted 29 August 2013 - 10:33 PM
Nice alternator!..........................
#19 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 29 August 2013 - 10:54 PM
Picture in Post 6 shows the gasket gone between the firings rings so would have been off soon
#20 MINIMAD555
MINIMAD555
  • 67 posts
Posted 29 August 2013 - 11:03 PM
hi really so it would of gone soon, how do you know from the picture that the firing rings have gone ?
#21 MINIMAD555
MINIMAD555
  • 67 posts
Posted 29 August 2013 - 11:04 PM
thanks m8, shame its already starting to pit, chrome is crap nowadays
#22 MINIMAD555
MINIMAD555
  • 67 posts
Posted 29 August 2013 - 11:05 PM
yea never using one again, got a piece of silicone hose spare from the hose kit i brought from my 1275 mini, so gonna use that :)
#23 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 29 August 2013 - 11:38 PM
Small area failed between cylinders 3/4 common place
#24 MINIMAD555
MINIMAD555
  • 67 posts
Posted 29 August 2013 - 11:53 PM
thats weird that i took that picture, i only took it to show the top of the piston and bore did not see the gasket gone between cylinder, good job i had to do the head, if i left it long would it of just blown between the cylinders ?
