Mr Mini - 1990 City
roundnose
12 replies to this topic
#1 Shylos
Shylos
  • 545 posts
Posted 18 March 2014 - 04:24 PM
I wondered if I would ever have a project thread here, but since my last MOT failure I figure now is the time to start one!
Mr Mini is a 1990 Midnight Blue City, and I have had him for... around 10 years now I would say. Off the road for a few years - firstly for new panels and a respray (not by me) and then while I sorted out cleaning and rebuilding the carb and a few other bits. Then the MOT happened and the rest is in Is It Time To Say Goodbye?... (http://www.theminifo...to-say-goodbye/)
First - a couple of pictures:
What's next:
Welding - the subframe mounts and the inside of a wing need doing. I have never welded before so this is a big challenge. I have access to the space I need, and a MIG welder etc, and somebody that knows what they are doing, so hopefully with practice I can get it done. I have bought the Haynes Restoration book which hopefully will be useful too - as well as this place! I still have some things I need to work out, including:
  • How to get to the underneath of the car - whether I need to buy/make a spit or if there is another way
  • What to replace - whole panels or just cut out the bits that need doing
Here's the problem areas:
20140314_164848.jpg 20140314_164928.jpg 20140314_165101.jpg 20140314_165018.jpg
These may need redoing - solid but looks grim:
and what looks like a crack in the subframe - not sure if fixable (wasn't picked up on the MOT)
Electrical - Sidelights and rear fog not working - although I could have sworn the sidelights were... Also the wipers - shouldn't be a problem.
Bearings - Excessive play, again shouldn't be anything big... hopefully.
So - after I have worked out how to get at what I need to get at, what exactly I am going to cut out and how to do it, it'll be all go!
#2 lewBlew
lewBlew
    Previously known as theboybradley.
  • 1,238 posts
Posted 18 March 2014 - 05:12 PM
Good for you in taking on the repairs. It looks like one of those 'parts cheap labour intensive' jobs which are incredibly expensive to get done by a garage but relatively cheap to do yourself.
Looks like a nice car. Look forward to seeing your updates. Whether you do it yourself or get some help (from this forum no doubt),  good luck!
#3 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 March 2014 - 05:14 PM
Good luck with this.
It is up to you what you do with regards to replacing whole or part panels and really depends on how much time you want to spend and of course your budget.
You are going to have lots of nasty rust behind those outer sills as they are not vented so you will need to factor that in.
As far as gaining access to the underside, a spit is ideal if you are going to strip the shell out completely but i have worked on the underside of mine simply by tipping it on its side either onto tyres or a mattress.
Welding skill is a must so plenty of practice is essential.
Plenty of helpful advice on here so ask what you need and you will be sure to get a reply!
Ben
#4 silve1999
silve1999
  • 1,146 posts
  • Local Club: MiniFreakz, Brighton Mini Club
Posted 20 March 2014 - 04:45 PM
Looks like a good project bit of work but certainly not too scary! :-) good luck ask questions and keep a lot of pics in the project log! :-D
#5 Covert
Covert
  • 526 posts
Posted 20 March 2014 - 04:58 PM
Good luck with the project , nice to see another one being saved
#6 Rocket.
Rocket.
  • 1,444 posts
Posted 30 March 2014 - 10:00 PM
looks like a good base !
#7 Hendred
Hendred
  • 484 posts
  • Location: Cleobury Mortimer Nr Ludlow, Shropshire Name: John
Posted 19 July 2014 - 09:04 AM
I just read your thread from when your mini failed it's MOT called 'is it time to say goodbye' and then found this thread, glad to see you decided to tackle it.
How is it going so far?
#8 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,188 posts
  • Name: Neil
Posted 19 July 2014 - 09:19 AM
You certainly have some work to do there. Ok start with the easier bits first.
Shock absorber mounts. You will need to take off the shocker mount itself here and be prepared to find a big hole behind it. Thus area is a twin skin area so will need to carefully cut and re fabricated to get right. It's not difficult to do but you need to remember about the nut blocks the shock absorber bolts to.
The subframe I'm very surprised the MOT did not find that. Instant fail. Now this can be repaired by welding the crack from both sides so will need the engine and subframe out.
Now for the biggie. Unfortunately you have got over sills fitted. This can be very bad news and will entail a lot of work to rectify. Take these off and see what is lurking. Be prepared for worst case scenario of new inner sill to the first flute. These can be bought from M a Machine and are not expensive.
Where the hole is in the rear of the outer sill is also where the rear subframe mounts. Again with the outer sill off you will see what exactly is going on there and this in itself may need the rear subframe off to carry out repairs.
#9 Shylos
Shylos
  • 545 posts
Posted 05 May 2015 - 10:42 AM
I can't believe it's been this long since I posted this thread... I think I have been too worried about starting it so put it off for a long time, but finally I have made a start. Nothing massive so far, but started stripping the engine bay ready for removal - I am planning on going with the shell over the engine method, and leaving the front subframe and engine behind.
I don't think I saw this when you first posted it - certainly given me more to think about! Sounds like the sills could be a real issue... With regards to the rear subframe, I was assuming this would have to come out anyway to weld the rear. Seems like it all could be even bigger than I first imagined...
#10 sonikk4
sonikk4
  • 16,188 posts
  • Name: Neil
Posted 05 May 2015 - 12:57 PM
It's always the same with minis , whatever you see on the surface is just the tip of the iceberg.
#11 Shylos
Shylos
  • 545 posts
Posted 23 April 2024 - 02:31 PM
Wow, this thread is ten years old... There's been a lot happened since then, and also very little.
A long story short...
I got all the welding done by someone in the end, because I didn't have the space to work on it myself, and I knew I wouldn't get around to it. But, just as things were finished, I moved to the USA.
So, I stored the Mini with the guy that did the welding while I figured out how I could ship it to the USA. In the meantime, he owed his landlord rent, the landlord sold some of the stuff in his workshop to get money back, and that included my Mini.
I didn't know that immediately, so registered it stolen. Cue lots of panicked phone calls, including speaking to the police who ended up getting it back from someone who (I assume) thought they had legit purchased a car.
I eventually got it back, then got shipping arranged and imported it to the US, where it then went into storage again until I could get a garage built to store and work on it myself.
I took it to a mechanic here for a once over, especially as whoever had it for a couple of weeks had started taking it apart, and all was good until I drove it home from the workshop and that radiator was leaking so bad it kept overheating and I needed to tow it back.
That brings me to now... I finally have my own garage large enough to work on the car, for the first time in my life. I am replacing the radiator, and while I am at it the fan, water pump, alternator and thermostat, with some other related bits and pieces.
While I am there, I am doing some more cosmetic things, like new hoses, rocker cover and such.
It's been the most work I have ever done myself, and a learning curve. Especially little things like not having the right bolts, running to the hardware store, then learning about bolt grades and ordering better ones online.
Also, I had purchased parts from suppliers in the US, until realizing Mini Spares is generally still cheaper and quicker delivery. I just need to not be as impatient as I am... placing an order only to realize the next day I need more!
I have a couple of pictures of it sitting in the garage as that was finished around the car, and a "before" of the engine bay. Hoping to have it back on the road in the next couple of weeks, with some better "after" pictures.
Also, I never want to remove/install a radiator again.
#12 KTS
KTS
  • 2,490 posts
Posted 23 April 2024 - 03:42 PM
wow - sounds like you were incredibly fortunate in getting the car back !
I'd have to agree; that garage does appear to be large enough to work on a mini   :lol:
#13 Shylos
Shylos
  • 545 posts
Posted 23 April 2024 - 08:20 PM
I definitely feel lucky to both get it back, and now have the space to work on it! Anything I have done up until now has been outside, it's nice to have an indoor space.
