I Decided It Was Time To Drag The Race Car Out And Update It.
roundnose
919 replies to this topic
#526 nicklouse
  • 19,067 posts
Posted 14 January 2019 - 11:33 PM
Right cat arrived. now need to make the openings the right size and get the welder out again.
#527 nicklouse
  • 19,067 posts
Posted 18 January 2019 - 10:28 PM
just checking that the manifold will not fit
not a hope in hell.
#528 nicklouse
  • 19,067 posts
Posted 23 January 2019 - 12:37 AM
ordered a new tray for the tool box and bought some stuff to use as a drawliner on the new cheap tool box
second socket tray for the 1/4 and 3/8 AF sockets to go with the MM tray.
also had a sort out of the other socket rail and you can see the material i used for the liner
most of these are 1/2" but are rarely used, the used ones are in the roll cab.
should have the exhaust sorted later this week just need to bash some metal.to get correct shape and fit.
#529 nicklouse
  • 19,067 posts
Posted 26 January 2019 - 07:43 PM
well after a week or so arsing about with where to put the cat. cutting tube and then welding it back together i have a solution.
finish off the last bracket. but dont have the rubbers so will have to just mount it direct for now so i can get the rest sorted and fitted.
#530 nicklouse
  • 19,067 posts
Posted 27 January 2019 - 06:30 PM
last bracket made  but not yet fitted as i am waiting on the rubbers as mentioned above so it was time to get the rear "diffuser" to fit
cut a hole
 enlarge it a bit
 need to measure up and remake a deeper center section
that needs cutting down before welding in place
#531 nicklouse
  • 19,067 posts
Posted 30 January 2019 - 11:59 PM
if you were wondering about the mounts/hangers
threads need trimming.
#532 nicklouse
  • 19,067 posts
Posted 31 January 2019 - 11:11 PM
guess where this will go
#533 nicklouse
  • 19,067 posts
Posted 01 February 2019 - 06:37 PM
started fitting this evening should be finished tomorrow.
#534 nicklouse
  • 19,067 posts
Posted 02 February 2019 - 06:22 PM
right all done. (well three more holes needed)
just need to strip and finish off the welding and add paint to the exhaust and the alloy.
#535 nicklouse
  • 19,067 posts
Posted 03 February 2019 - 07:04 PM
sooooo inspection hatch for the cat (rules and regs).
finished welding up most of the exhaust and brackets so while waiting for things to cool and paint dry i finished of sorting sockets.
#536 nicklouse
  • 19,067 posts
Posted 04 February 2019 - 07:06 PM
might have to change something
#537 KTS
KTS
  • 2,490 posts
Posted 04 February 2019 - 07:39 PM
whats going on there !?!?!
#538 nicklouse
  • 19,067 posts
Posted 04 February 2019 - 07:45 PM
Kat getting warm
https://youtu.be/_wwrkxsR8BY
#539 johnR
johnR
  • 2,324 posts
Posted 04 February 2019 - 07:51 PM
Looks neat - is the idea of the housing to keep heat in the exhaust to aid flow or for aerodynamics?
#540 nicklouse
  • 19,067 posts
Posted 04 February 2019 - 07:57 PM
i think i will actually need to get heat out of the system. see video and pics above.
