I Decided It Was Time To Drag The Race Car Out And Update It.
roundnose
919 replies to this topic
#571 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 11 June 2019 - 07:29 AM
Looking good Nick! Do you have some outings planned for the car?
#572 nicklouse
  • 19,058 posts
Posted 16 June 2019 - 08:06 PM
todays job.
new bits on the way.
#573 nicklouse
  • 19,058 posts
Posted 19 June 2019 - 11:44 PM
Mmm tomorrow I make a tool to but a bead in some pipe. Should be fun then I can see if the new delivery fits.
#574 nicklouse
  • 19,058 posts
Posted 20 June 2019 - 08:03 PM
so the bits i was waiting for arrived.
add some existing bits. no idea if both will fit at the time of photo.
so as of the end of play today.
brackets done.
hoses made.
rad fitted.
 need to get more ties for the fan and work out some means of plumbing in the expansion tank.
did not need the alloy tube in the end.
#575 nicklouse
  • 19,058 posts
Posted 21 June 2019 - 08:37 PM
long drive today just for some small bits
and the Minispares order should be here on Tuesday.
#576 nicklouse
  • 19,058 posts
Posted 22 June 2019 - 07:29 PM
so what were the bits for.
finally decided to make the DSN fuel breather usable with some heat shield.
filtered the coolant
all together and running with no leaks. just need to sort out catch tanks
#577 nicklouse
  • 19,058 posts
Posted 26 June 2019 - 12:30 AM
minispares delivery this morning this and other bits.
and a couple of tanks.
#578 nicklouse
  • 19,058 posts
Posted 26 June 2019 - 12:33 AM
got into the garage this morning. still 32 degrees.
stripped the grill
now to get a sheet of aluminium to replace this and to mount the above on.
also stripped down one of the tanks to see how much they actually hold. 1/2 Liter
#579 nicklouse
  • 19,058 posts
Posted 27 June 2019 - 02:19 AM
so a couple of hours after work i worked out how i am doing things.
slats modifying tomorrow.
#580 nicklouse
  • 19,058 posts
Posted 28 June 2019 - 02:13 AM
more holes drilled a primer on. will try and get some colour on in the morning so assembly can start after work friday.
#581 nicklouse
  • 19,058 posts
Posted 29 June 2019 - 12:39 AM
arse
#582 nicklouse
  • 19,058 posts
Posted 29 June 2019 - 12:40 AM
on a plus note the big breather connection has been done.
#583 nicklouse
  • 19,058 posts
Posted 29 June 2019 - 11:07 PM
well not quite sure what is going on with number 5
but other wise quite happy.
the back has been relived to remove most of the airflow hindrances.
just needs more time with the die grinder. but was getting tired.
#584 nicklouse
  • 19,058 posts
Posted 30 June 2019 - 08:54 PM
tah da
still got the breather tank to do for the other side.
#585 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 01 July 2019 - 12:25 PM
That does look good!
    Bing (2)
