Aasnes1`s 1977 Mini.
roundnose
160 replies to this topic
#136 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 05 April 2015 - 12:16 PM
Nice work on the polishing. Really brings out the black colour.
#137 Aasnes1
Aasnes1
  • 120 posts
Posted 05 April 2015 - 12:41 PM
Thanks!
Now i have to wait for the starter to arrive, pretty nervous, hope i get it to start! :)
#138 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 05 April 2015 - 12:49 PM
Have faith in your building skills :) Soon you'll be flying on the roads
#139 Woody001
Woody001
  • 42 posts
Posted 05 April 2015 - 09:28 PM
Really nice build, well done.
Have you checked that you have a good earth to the engine? If you put a voltmeter between the battery negative and the engine, read what volts you have whilst cranking the engine over. The voltage displayed will be the loss in the system from a bad earth.
I think you are doing the correct thing in buying the high torque starter, mine struggles to crank with the standard starter also.
Keep up the good work.
#140 Aasnes1
Aasnes1
  • 120 posts
Posted 06 April 2015 - 07:57 AM
Thank you!
I have not checked with a voltmeter, but i have used jumpercables from negative on battery to starterbolt, and from plus on battery to solenoid, and nothing changes.
So i think the hi torque will do it:)
And by the way, before i got the starter i got now, the old one caught on fire, that one allso turned slowly.
#141 Woody001
Woody001
  • 42 posts
Posted 06 April 2015 - 04:43 PM
Thank you!
That's good, although not the catching fire part! :-)
#142 Aasnes1
Aasnes1
  • 120 posts
Posted 06 April 2015 - 08:30 PM
Thank god it was snow outside when it happened 😂
#143 Aasnes1
Aasnes1
  • 120 posts
Posted 10 April 2015 - 08:01 AM
Finally some parts arrived :D
#144 Aasnes1
Aasnes1
  • 120 posts
Posted 10 April 2015 - 04:17 PM
The new starter is a biiig improvement! Now it turns over superfast :D
It fired up a couple of times, but wont fully start, tomorrow i will go over the ignition parts, timing, and get some fresh fuel on it :)
#145 Aasnes1
Aasnes1
  • 120 posts
Posted 10 April 2015 - 04:25 PM
Edited by Aasnes1, 10 April 2015 - 04:32 PM.
#146 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 10 April 2015 - 05:34 PM
Well done dude! Nice to hear that the high-torque starter sorted the turning over issues :)
#147 Aasnes1
Aasnes1
  • 120 posts
Posted 10 April 2015 - 07:35 PM
Thanks! So happy it was the starter:D
Here's a video, the old starter used allmost 2sec to turn it over one turn, if you understand :P so a big improvement :)
http://i61.photobuck...zpskrjeuibg.mp4
Edited by Aasnes1, 10 April 2015 - 07:39 PM.
#148 Aasnes1
Aasnes1
  • 120 posts
Posted 11 April 2015 - 05:21 PM
It`s running!!!! cleaned the spark plugs, drained fueltank and filled it up with fresh fuel, set the timing at 8dgr BTDC and it started right up!
Have to do the timing with a lamp too perfect it :)
here`s a link to video of it running!
http://vid61.photobu...zpsl11kgnk3.mp4
But i have a big clutch problem, have way too much freeplay, don`t know what to do, probably need to take the cover of and see :/
Edited by Aasnes1, 11 April 2015 - 07:23 PM.
#149 BlueAnorak
BlueAnorak
  • 10 posts
Posted 12 April 2015 - 12:00 AM
The release plunger appears to have travelled too far in to the clutch cover.
Possible causes of this could be:-
1) Did you fit the bearing to the release plunger?
 It is possible it could have fallen off during assembly as there is no circlip to hold it in place.
2) Were both the thick, keyed washer and lock washer fitted when fitting the flywheel retaining bolt?
3) Were either the flywheel or pressure plate lightened by removing material from the bearing surfaces?
4) Have you mixed Verto and pre-Verto parts?
#150 Aasnes1
Aasnes1
  • 120 posts
Posted 12 April 2015 - 07:02 PM
1) that is a possibility, but wouldnt it make a noice when the engine is running?
2) yes.
3) no.
4) no.
    Bing (1)
