Aasnes1`s 1977 Mini.
roundnose
160 replies to this topic
#151 Aasnes1
Aasnes1
  • 120 posts
Posted 14 April 2015 - 09:29 PM
It's drivable!! So happy 😀
I took of the clutch cover, and see that the flywheelbolt is touching the diaphragm (see pic), so i took off the flywheel, and then the stupidity reveals it self..... !I HAVE PUT THE CLUTCHPLATE THE WRONG WAY!.....
So i got everything sorted out and now the clutch is perfect!
Well not perfect, it's going to be replaced someday, flywheel and pressureplate have some spots and needs replacing in the future, then the arm, plunger, Rod and all pins going to be replaced :)
DSC_1502_zpsou2dv2lz_edit_1429046858611_
Edited by Aasnes1, 14 April 2015 - 09:34 PM.
#152 Aasnes1
Aasnes1
  • 120 posts
Posted 15 April 2015 - 09:20 AM
Good to see it out in the sun again :)
And now im ready to capture the Mini moments with my new GoPro!
Edited by Aasnes1, 15 April 2015 - 10:36 AM.
#153 Woody001
Woody001
  • 42 posts
Posted 16 April 2015 - 08:04 PM
Glad you got the clutch sorted.
I like that starter motor, I think I'm going to have to start saving for one!
#154 Aasnes1
Aasnes1
  • 120 posts
Posted 17 April 2015 - 08:00 PM
Can't get it to run right, as soon it's warm it start to missfire and stalls, have checked everything except valve clearence and carb adjustment, so thats next:)
Got the brakes working again, left rear brake cylinder was stuck, but i got it loose again with some force!
Got my new vintage licenceplate, and love it! Allso got the second bonnetstrap on.
Gave the car a good clean and got some nice pictures of it!
Need to shorten in the exhaust a bit!
Edited by Aasnes1, 17 April 2015 - 08:01 PM.
#155 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 17 April 2015 - 08:02 PM
The fourth picture should be your new profile pic :)
#156 Aasnes1
Aasnes1
  • 120 posts
Posted 17 April 2015 - 08:03 PM
The starter is the best upgrade i have done :P can't compare it with the old one in any way! Much smaller allso:)
#157 Aasnes1
Aasnes1
  • 120 posts
Posted 17 April 2015 - 09:03 PM
You are right! And it`s done! :)
#158 Aasnes1
Aasnes1
  • 120 posts
Posted 19 April 2015 - 08:25 AM
a little video of it running fine when cold.
#159 korky
korky
  • 74 posts
Posted 19 April 2015 - 04:01 PM
 Very nice sound! You should do a video when driving it.
Also, what have you put on your headlights to give them that effect we see on the pics? Photoshop?
#160 Aasnes1
Aasnes1
  • 120 posts
Posted 19 April 2015 - 05:29 PM
Thank you, i will when i get it to run right:)
No, they are like that, bought them here:http://www.minispare...ssic-mini-pair/
#161 Aasnes1
Aasnes1
  • 120 posts
Posted 21 April 2015 - 10:51 AM
finally got it to run OK, the valve/tappets clearance was too tight! so i adjusted them to 0.40mm and i allso adjusted the carb.
when i did that i got to set the timing, i set it at 12 degree at 1000rpm, and it`s runnin ok, but i need to change the needle in carb, it is worn and a little bit bent. have allso ordered a service kit for the carb :) i hope that fixes the small "missfire" when i accelerate.
Here is a list of whats comming in the mail next:
- CHOKE CABLE RUBBER TYPE PULL and TWIST UP TO 1987
- HEATER CONTROL CABLE 1969 TO 1988
- CHOKE CABLE TRUNNION ACH9042 NIPPLE and 53K3503 SCREW
- PERFORMANCE 8mm PLUG LEAD SET
- HEATER VALVE NON GENUINE
- CLUTCH THROW OUT PLUNGER LARGE NUT
- HIF44 CARB SERVICE KIT - EXCEPT TURBO
- FUEL FILTER 1/4
- NEEDLE BCV SWINGING TYPE CARB
- ACCELERATOR CABLE LHD 1275 CARB MODEL 1990 ON
Edited by Aasnes1, 21 April 2015 - 10:53 AM.
    Bing (2)
