Layzeboy's 93 Sprite Build
roundnose
32 replies to this topic
#16 LAYZeBOY14
LAYZeBOY14
  • 40 posts
  • Local Club: GMOC
Posted 03 January 2016 - 01:58 AM
So after many thoughts of keeping the original grill. and the bonnet lip i have ended up with this.
prefer the mk1 front end look so ive cut the bonnet lip off. and have come up with a idea that i can use the original grill with the bonnet lip which will be removable so i can switch between what grill i want to use :)
you can see the original grill i had before :)
#17 LAYZeBOY14
LAYZeBOY14
  • 40 posts
  • Local Club: GMOC
Posted 03 January 2016 - 02:21 AM
when i purchased the car the carpets and seats where taken out as the previous owner said there was a little water leak somewhere and was getting wet under investigation to try and find it i never did. was dry for a few months then started to get wet on the floor again the previous owner said it had been repaired before but that obviously wasnt the source to the problem. anyway as im going for show spec. and will be used some track days. i didnt like the look of the inner sills looks although before hand its been repaired instead of cutting the panel out its was just patched over. so as im gonna be running the car with no sound proof or carpets i didnt like the idea of looking at the patches so decided a new inner sill door step and outer sill was the only option.started cutting a proding i have found this.
The floor is solid just the inner sills
things got a little worse while investigating the inner sills.
drivers side !
THIS WAS FULL OF FILLER !!!
WAS TIME TO REMOVE IT ALL AND ENDED UP WITH THIS ! in all honestly it was that bad wasnt rotted atal inside.
#18 Van13
Van13
  • 314 posts
  • Local Club: Unknown
Posted 03 January 2016 - 08:58 AM
Nice car keep up the good work, it's good to see projects been done right first time
I take it you can weld
#19 jpw1275
jpw1275
  • 2,803 posts
Posted 03 January 2016 - 10:15 AM
Your doing a good job mate ...... Keep it up
Cheers james
#20 gadget555
gadget555
  • 152 posts
Posted 03 January 2016 - 10:46 AM
Looking good keep up the good work:-)
#21 LAYZeBOY14
LAYZeBOY14
  • 40 posts
  • Local Club: GMOC
Posted 03 January 2016 - 01:47 PM
Thanks :) yeh i can weld
#22 LAYZeBOY14
LAYZeBOY14
  • 40 posts
  • Local Club: GMOC
Posted 03 January 2016 - 02:04 PM
Bit of an update. managed to get some panels. got them all prepped up and cut and test fitted to size.
More photos to follow :)
#23 MrBounce
MrBounce
  • 2,686 posts
Posted 03 January 2016 - 02:09 PM
It's amazing how something can look solid enough and then with a bit of a poke it suddenly becomes a mass of rust and holes. Good work though - well done :thumbsup:
#24 LAYZeBOY14
LAYZeBOY14
  • 40 posts
  • Local Club: GMOC
Posted 03 January 2016 - 02:17 PM
Your correct there Mrbounce. i dug around to find out what happened and imformation came back the lady owner always had a mechanic that always got it through a mot. no surprise there by the work that was carried out.
anyhow its done proper this time and the car is completely rot free just those patches that i wasnt happy with. deadline is around end of april ready for L2B this years :)
#25 LAYZeBOY14
LAYZeBOY14
  • 40 posts
  • Local Club: GMOC
Posted 04 January 2016 - 11:37 PM
UPDATE ! got the drivers side all welded up and painted now on to the passenger side were more hidden secrets are reveled no doubt.
also started to strip the engine! gearbox needs refurb as first gear is crunching too much :(
#26 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 05 January 2016 - 06:39 AM
Nice little project, I feel the pain from having a car that looked on the floors to having to cut the whole of the inner sill etc out mine was due to over sills but still it didn't look as bad as it all turned out.
Keep the pics coming :)
#27 Steve220
Steve220
  • 5,140 posts
  • Local Club: BMC
Posted 05 January 2016 - 01:59 PM
Excellent progress. You going to give the gearbox work a go yourself?
#28 James_eaton_thewholething
  • 1,063 posts
Posted 05 January 2016 - 07:39 PM
Good work, looks like it will be up and running in no time
#29 LAYZeBOY14
LAYZeBOY14
  • 40 posts
  • Local Club: GMOC
Posted 05 January 2016 - 09:00 PM
Thanks guys :) none of this was never part of the plan. the intention was to put it away for the winter to do engine work and just redesign the whole interior and have the car painted the body is immaculate. besides the inner sills, the car has never been touched so this is the first time the car has been cut apart.  plans changed and wasn't happy with over plates on inner sills so had to go. the paint is original from factory apart from the roof which was sprayed white.
Car will have a resh repsray in the same color as its currently like 50 shades of red due to sun damage, but what red car doesn't lol
Update later on progress of passenger side
Stay tuned :)
#30 LAYZeBOY14
LAYZeBOY14
  • 40 posts
  • Local Club: GMOC
Posted 05 January 2016 - 09:02 PM
No im  gonna take the gearbox to a  local mini specialist to save up some time so can crack on with the rest of the welding. otherwise i would do it myself !
