Time to wire in the Fuel Pump.
First i picked this spot to mount the pressure switch. It keeps it away from everything and its a good earth point.
Next i wired up the relay (on the right), left is for the spot lights.
bolting the fittings together and getting ready to connect to the oil pressure gauge
Front part done.
Now to mount the fuel pump - I decided to mount it under the tank on the rear sub-frame.
I protected the powered wire from the rubbing of the chassis by feeding it through a vacuum hose
