4 replies to this topic
Posted 18 January 2017 - 08:47 PM
Hey guys! I've just fitted the powerspark electronic ignition to my 59d dizzy. Went in nicely apart from the original screw which held the points in place is too short! The kit says I should be able to re use the existing screws, am I missing something?
Posted 18 January 2017 - 09:14 PM
Fitted several not come upon a short screw not being able to screw the replacement baseplate down, maybe your points screw was a shorter one than O.E ?
Posted 18 January 2017 - 10:50 PM
Thanks for your reply, very possibly shorter than O.E. Do you know the part number or perhaps the screw/thread size?
Posted 19 January 2017 - 09:28 PM
From memory 2BA check Minispares they have a full set of the screws listed on their site if you need more than the points one, or ebay here and cut one to the length you require http://www.ebay.co.u... screw&_sacat=0
Edited by KernowCooper, 19 January 2017 - 09:34 PM.
Posted 19 January 2017 - 09:58 PM
Awesome thanks man :)
Mini Technical Sections →
Problems, Questions and Technical →
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Mini Spi Charging IssueStarted by Dutch_MiniSPI , 27 Mar 2024 electrical |
Main Dipped Beam Not Working - Just Before Mot :-(Started by Park , 24 Mar 2024 electrical |
Speeduino EcuStarted by cooperpooper , 09 Mar 2024 electrical, engine |
Smiths Electronic Speedo Accuracy?Started by chuee , 01 Mar 2024 electrical |
