Clubman Estate Wiring Issues
electrical
4 replies to this topic
#1 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 25 April 2017 - 09:23 AM
Hiya folks me again!
Last night I'd changed the terminals on my estates fusebox(four fuse box)
Car is a 1980
I have a fault where if I turn the ignition on the red light and sidelights come on and stays on until I remove the two brown wires at the fusebox!
Does anyone have a wiring diagram of the fusebox and also for the car?
I have tried a few different positions for wires but always went back if it didn't work
Edited by cal844, 25 April 2017 - 05:53 PM.
#2 Rapidmini59
Rapidmini59
  • 195 posts
  • Local Club: Minifreaks
Posted 28 April 2017 - 07:01 PM
Terminals as follows for fuse box left side first
1-white for ignition and white for coil positive
3-brown from lighting switch and brown from starter solenoid
5-lightgreen/white from ignition
7-red from lighting switch
Right side of fuse box
2-green to stop lamp switch hydraulic or mechanical and green to indicator flaser unit.
4-purple to headlamp flasher switch on steering column
6-light green/orange to combined windscreen wiper and washer unit
8-red/green to nearside and offside tail lamps,both front side lights and number plate lights
Fuse box is as follows
1-----2
3-----4
5-----6
7-----8
This looking at the fuse box when you take the cover off to see the fuses.
Hope this help
Regards
Rapidmini59
#3 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 28 April 2017 - 07:55 PM
Thanks mate, followed the wiring diagram, with assistance from a wiring guru, got everything working as it should
A couple wires in the wrong places(green and green/orange mixed up)
Then the sidelight feed mixed up with a stereo power wire
The lack of all indicators/hazards was foxed easy enough(cleaned relays and pulled switch out the dash slightly, the plug has Been butchered!!)
#4 Rapidmini59
Rapidmini59
  • 195 posts
Posted 28 April 2017 - 10:13 PM
Excellent
Glad you sorted it
#5 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 29 April 2017 - 10:54 AM
Excellent
Glad you sorted it
I'm useless with electrics, it was my mate who takes the honours lol
