right just wondering you often see the inside of blocks been painted and the inside of rockercovers have a "paint" on the inside.
what type of paint do you use?
if any....
Posted 05 May 2018 - 11:09 AM
if any....
Posted 05 May 2018 - 02:23 PM
Posted 05 May 2018 - 06:30 PM
I've seen this before, very badly painted engines by 'Professionals'
Valve gear, crank inside of gearbox painted....
Posted 05 May 2018 - 06:55 PM
Posted 05 May 2018 - 06:59 PM
Usually red oxide on iron blocks to stop the oil seeping through the block - believe it or not
Posted 05 May 2018 - 07:05 PM
There are special 2 part epoxies for this. Supposingly to make the oil run down faster.
Posted 05 May 2018 - 09:17 PM
Vizard advocates painting inside and out - I've etch primed the inside of my rocker covers and was wondering whether to paint the rocker area of the head with the same.
Posted 05 May 2018 - 09:19 PM
er that's a no from me what's the point if ya did , Cannot see it , and only probly block ya oil pump up or galleries and cost ya 50bhp in weight , not like its a red strip, think maybe years ago they might have done it on 1929 mini 's' works twin turbo coppers stop the block rusting like the rest of it................P.s. the 1929 models rusted that bad and quick there like rocking horse fairy poo now......
Yes I think it's fair to say 1929 minis are rare!
Posted 14 May 2018 - 09:51 AM
See no reason to do it...pointless exercise to gain nothing with potential downsides.
Never seen it anywhere in any tuning books including Vizards
Posted 14 May 2018 - 02:27 PM
Posted 14 May 2018 - 07:37 PM
I can confirm VIzard recommended painting the block interior in the Yellow Bible.
Posted 14 May 2018 - 11:28 PM
I stand corrected, what page...?
Posted 14 May 2018 - 11:38 PM
could no see it after a quick scan through my self.
Posted 15 May 2018 - 01:07 AM
Page 42, top right. He actually said to red primer the inside, not paint.
Posted 18 May 2018 - 04:39 PM
A NOS 1275 block that i managed to source was.
if any....
Mini Technical Sections →
Problems, Questions and Technical →
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Which Rocker ArmsStarted by mark the diver , 30 Mar 2024 engine |
