Posted 01 June 2018 - 08:33 AM
I have gone to replace the fuse box on my 1980 clubman, as all the electrics are playing up (no lights, front or rear, fuel gauge/ engine temp gauge not working etc)
When I pulled the wires out to replace the fuse box I noticed the ends of the wires (that fit into the clips) are all corroded, what can I do to make these work again or is it going to be a replace the entire wire loom job?!
Some of them aren’t as bad as others, but I’m assuming that’s what’s causing the headlight issues (the brown wire was the most corroded & that is supposedly the wire for the headlights!!)
Thanks!
C
Posted 01 June 2018 - 08:41 AM
Posted 01 June 2018 - 01:35 PM
What I did on mine, as I had the same problem on a couple of the wires, (obviously disconnect the battery) Mine were green with corrosion and wouldn't have soldered so I cut back the minimum I could get away with as there isn't much slack in the wires, tinned the ends and soldered on brass spade terminals (with the slip over plastic insulators). If your wires are too short, you could solder on short extension pieces and use heat shrink over the join then solder on a spade terminal to the extension piece. It is fiddly and awkward to get at but mine have been fine ever since and I didn't have to disturb the fuse box.
Posted 01 June 2018 - 01:43 PM
Edited by RedRuby, 01 June 2018 - 01:43 PM.
Posted 01 June 2018 - 02:44 PM
I would suggest you contact “wired by Wilson” on here and invest in one of his replacement bladed fuse boxes they come with prewired connectors of a good length which would allow you to cut back yours without worrying that they end up too short. You could also ask if he could provide you with the replacement male connectors you will be cutting off. Good value at about £25
Plus one on this also worth investing in a ratchet crimping tool makes the world of difference to crimped joints.
Posted 02 June 2018 - 08:13 PM
Next job: fuel and engine temp gauges not working!
THANKS for all your help and advice, fantastic as always !
C
Mini Technical Sections →
Problems, Questions and Technical →
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Mini Spi Charging IssueStarted by Dutch_MiniSPI , 27 Mar 2024 electrical |
Main Dipped Beam Not Working - Just Before Mot :-(Started by Park , 24 Mar 2024 electrical |
Speeduino EcuStarted by cooperpooper , 09 Mar 2024 electrical, engine |
Smiths Electronic Speedo Accuracy?Started by chuee , 01 Mar 2024 electrical |
