Mini Wont Start But Will Run W/bump
electrical
Best Answer cal844 , 09 October 2018 - 08:26 PM
Test for power at the white/red on the solenoid (if not it will be the ignition switch)
If there is power on the above then check that the solenoid is earthed to the inner wing(clean, shiny metal on the solenoid and wing) then check the boot floor to battery terminal earth Go to the full post
15 replies to this topic
#16 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 10 October 2018 - 01:26 PM
That is an interesting piece of information and something i did not know. I will have to look at mine before i try starting it as the last owner said he could not get it to run
Happy to help, if it doesn't have power check the ignition switch terminals for corrosion
