Posted 06 March 2019 - 11:44 PM
Posted 07 March 2019 - 03:54 AM
Clean the grease off it and then polish it up with some scotch bright, a wire wheel or some 600 then 800 abrasive paper. It'll be fine.
Posted 07 March 2019 - 09:18 AM
I bought a set o med straight cut drop gears, packed them with oil and paper , unfortunately mice ate the packaging a rust attacked the gears so now I think oil will pass the oil seal to the clutch, what do you think?
That 'diameter' is not critical, in fact it doesn't even have to be circular, the flexibility of the oil seal will cope.
Next time, don't wrap it in your old "Fish n Chip" paper.
Posted 07 March 2019 - 03:57 PM
Posted 07 March 2019 - 03:58 PM
Posted 08 March 2019 - 02:30 PM
Use one of the black clutch seals they are about 30 thou smaller ID and better than the standard orange things.
http://www.retromini...products_id=273
10 off for TMF too.
Posted 09 March 2019 - 07:14 AM
Mini Technical Sections →
Problems, Questions and Technical →
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Which Rocker ArmsStarted by mark the diver , 30 Mar 2024 engine |
