Posted 14 April 2019 - 09:01 AM
Posted 14 April 2019 - 09:52 AM
Not really - It just helps with the sealing.
One thing to remember is the flexible pipe the hard line connects to will have possibly swollen a bit and dried up a tad. In this case if you are using the correct sized hard line (replacement) - it may feel a bit loose, so best to replace the rubber piping too
Just a case of not mixing old with new. Best to use new clips too if they are as old as the line.Just a safety thing really, you don,t want fuel leaks
Edited by richmondclassicsnorthwales, 14 April 2019 - 09:55 AM.
Posted 14 April 2019 - 09:54 AM
Cannot speak for everyone else but the original factory steel fuel lines on my 1982, 998 didn't have any flares at any of the fuel line joints. I think the key is to match the correct size tube (1/4"O/D x 22swg) to the correct size rubber hose (1/4" I/D) at any of the joints using the correct size clips think 11-13mm are the ones you want though I stand to be corrected on that. You don't state which model you have, I think, though not certain the injected cars may have had larger lines.
Posted 15 April 2019 - 02:31 PM
Mini Technical Sections →
Problems, Questions and Technical →
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Which Rocker ArmsStarted by mark the diver , 30 Mar 2024 engine |
