Bleeding The Master Brake Cylinder
brakes
17 replies to this topic
#16 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 16 September 2019 - 09:42 AM
Yes I do have a hose with one end in a jar under the Brake Fluid level so it cant draw air back in
#17 leeesslemont
leeesslemont
  • 10 posts
Posted 16 September 2019 - 05:54 PM
Update.........
Now bled each of the corners again.  No difference from the 1st time. I have to leave it for a couple of weeks now as I have to go away for work.
I will re-convene when I get back.
****oooops.  My bleed nipples on the calipers are on the bottom.  I guess I need to swap the calipers so the nipples are on the top
Edited by leeesslemont, 16 September 2019 - 06:00 PM.
#18 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 16 September 2019 - 08:10 PM
Update.........
Bingo!
I bet when you put the nipples to the top you'll have a perfect pedal.
Yes I've had someone fit calipers to one of my minis to the wrong sides... so the nipples were on the bottom and thus no pedal but It would pump up.
Changed the calipers side to side and it fixed the issue on the first bleed
Edited by cal844, 16 September 2019 - 08:10 PM.
Also tagged with one or more of these keywords: brakes
