Drum Won't Fit Over Ms2693 Front Brake Assembly
brakes
3 replies to this topic
#1 bemayr
bemayr
    Starting My Mini Up
  • 1 posts
Posted 16 June 2026 - 05:32 PM
Hi all,
I'm currently in the process of getting my 850 back on the road. Last week, after replacing the wheel bearings, I went to put everything back together — but now the brake drum simply won't go over the wheel cylinder and shoes.
The adjusters are wound all the way back to their minimum, but when I try to fit the drum, it won't go over the brake assembly. Oddly, this is only happening on one side. The backplate, wheel cylinder, and shoes are all from the Minisport MS2693 front drum brake assembly kit (https://www.minispor...-1959-1984.html), and I'm using the standard drums.
Has anyone come across this problem before, or have I missed something obvious? Could there be a manufacturing tolerance issue with the MS2693 kit? Interestingly, the MS2693 also seems to no longer include the spring that sits between the wheel cylinder and the shoe.
Many thanks in advance and best regards,
Bernhard
As I've got issues with uploading images here, I've already asked in the German Forum and there is a visual representation of the problem: https://www.mini-for...919#post1154919
#2 Quinlan minor
Quinlan minor
  • 1,374 posts
Posted 16 June 2026 - 07:32 PM
Not having experience of front drums, I can only observe that the arrowed return spring doesn't look like it's properly located, to me.
Edited by Quinlan minor, 16 June 2026 - 07:32 PM.
#3 68+86auto
68+86auto
  • 1,461 posts
Posted 16 June 2026 - 11:24 PM
The shoes can also slide up and down. Have a look where the drum is hitting and push the shoe in the opposite direction.
#4 timmy850
timmy850
  • 3,600 posts
  • Local Club: MITG
Posted 17 June 2026 - 12:48 AM
Do the pistons in the wheel cylinders move in and out smoothly? Are they pushed all the way in?
The adjusters also from the picture above don’t look to be in the neutral position, they could be rotated to allow the shoes to go in closer.
The mechanic I went to always told me to tighten them up (once the drums are on) in the same direction that the wheels spin when driving forward to adjust them properly. There should be a slight audible drag on each shoe. Once you’ve set it and bled the brakes, the shoes can centre better in the drums, and you’ll need to adjust them again
Also tagged with one or more of these keywords: brakes
