Hi all,
I’ve made similar posts regarding a rough ideals / cut out after immediate start up which usually sorts itself out after a couple minutes warning up.
This time however my car (even when warm) will completely cut out when I go to break or clutch break.
I have noticed it also had a fairly rough idle now which it didn’t before.
Only thing that is different is that there are new vacc lines / fuel trap intake , ignition coil and radiator hoses.
Car starts fine and used to occasionally cut out if driven immediately after starting when you went to stop.
Now however the problem appears to be worse and cuts out whenever I go to break unless I literally tap it and roll to a stop.
My mechanic thinks the distributor cap could be wet and I should get a cover but this just sounds like the problem I already had has been exacerbated.
Any help appreciated . Thanks
96 Spi Cuts Out When Breaking
MarkC123
, Oct 25 2019 02:46 PM
engine electrical suspension
3 replies to this topic
Posted 25 October 2019 - 02:46 PM
Posted 25 October 2019 - 05:23 PM
Is it idling between 850/1000revs when hot , if below this it could stall . Has the stepper motor been set correctly, you will need a diagnostics machine to do it. Check the crank sensor near to starter motor this might be playing up. Check all connections are ok
Did you change the two vacuum connections on the inlet manifold as well
Edited by hunterg30, 25 October 2019 - 05:29 PM.
Posted 25 October 2019 - 05:35 PM
check earth strap engine to bulkhead
Posted 18 July 2020 - 05:27 AM
did you find a solution to your problem? If yes, what was it?
Also tagged with one or more of these keywords: engine, electrical, suspension
Mini Technical Sections →
Problems, Questions and Technical →
Clutch Disengagement Issue - Cosworth Bda MiniStarted by cooperbloke , Yesterday, 10:15 AM |
Turn Signal/indicatorsStarted by oldman1001 , 30 Sep 2026 |
12G202 On A 998Started by Mini30BVA , 28 Sep 2026 |
Engine Surging Then StallingStarted by Adge456 , 06 Sep 2026 |
Stuck Exhaust ValveStarted by JimmyStinkpickle , 28 Jul 2026 |
