Good morning all. It's been a long time since I’ve posted in here, but I do constantly use it as a reference. The assembled knowledge base in this forum is amazing and sets it apart from others. Thank you.
With that, I would like some guidance myself now please. I have built a 1299cc Cosworth BDA ‘screamer’ on a modified remote-type Jack Knight dog box using an original one piece Gordon Allen steel crankshaft. Both the engine and the gearbox have been fully checked and rebuilt. Over the summer I’ve installed it my spaceframe Mini and now I’m struggling to get the clutch to fully disengage so I can cleanly select a gear. I know it’s a dog box so ‘on the move’ selection may need to be aggressive, but I can’t disengage the clutch to get first (or reverse) to get moving.
Here is a list of the equipment fitted and the efforts I’ve taken to get the clutch to disengage sufficiently. The Mini has an adjustable Tilton pedal box. The clutch pedal stop screws are set for maximum stroke. This pedal box was working well with the previous A-series engine and rod-change 'box. The clutch arm, bearing carrier, both clutch arm clevis pins and the slave cylinder are new. I’ve fitted an adjustable clutch pushrod and it’s set so the CSC piston is fully retracted for maximum stroke. The throw-out nuts are temporarily backed out (so they have no influence on max clutch operation.) I’ve adjusted the clutch arm stop-bolt to have minimal clearance for maximum operation. I’ve bled the clutch – there’s no air in system. In fact, the clutch arm operates immediately with no ‘slop’. I’ve spaced the bearing on the carrier away from the cover so there’s minimal clearance to the diaphragm bearing plate. There was originally a 9mm gap!
The following do not have any bearing on clutch operation, but I found them interesting enough to share. The flywheel on the crank relies on the taper only – there is no flywheel keyway. The taper on the crank and in the flywheel centre are unique and not the same as a standard Mini taper. The arrangement does not have a ‘C’ washer or thrust plate for the primary gear. This unit was originally competitive in motorsport in Sweden ‘back in the day’. I bought in UK but had been fully dismantled.
My feeling is that the machined height of the three ears on the pressure plate may need to be adjusted, but I'm inclined to think it must have been correct at one point in time. I'm confident the parts I have are all original to this engine and 'box, but I can't be sure there was nothing missing...
Does anyone have any more suggestions? Happy to provide any additional photos if required.
Thank you in advance!
Steve
