Posted 06 September 2026 - 04:16 PM
I've been working on my mini for a while after it sitting for 6 years with a blown head gasket. I've got it 'running'. With the choke out, it runs ok but when it's up to temp and I take the choke off, it drops revs a lot, then picks up a bit then drops off again.
My thoughts was to increase the idle but it just surges higher then almost stalls and repeats this. I then thought maybe it's too lean, increasing revs but almost stalling due to fuel starvation? I've adjusted it slightly but don't want to carry on as I may make things worse if I follow my untrained intuition. Perhaps it's too rich and flooding? I just don't know.
Any help would be great.
It's a 998 with a HS4 carb.
Posted 06 September 2026 - 05:44 PM
How old is the fuel in it ?
The other thing is there's every chance the fuel system has dried gunnmy residue through it and will likely need a clean out.
Posted 06 September 2026 - 05:53 PM
I have a glass fuel filter and the fuel seems to be clean coming in, no bits in the filter, no odd color. The float has been cleaned also.
Posted 06 September 2026 - 06:55 PM
Posted 06 September 2026 - 07:20 PM
Posted 07 September 2026 - 12:55 AM
Posted 07 September 2026 - 05:04 AM
Posted 09 September 2026 - 02:42 PM
Posted 09 September 2026 - 03:37 PM
Posted 09 September 2026 - 06:40 PM
Posted 09 September 2026 - 08:18 PM
Posted 10 September 2026 - 03:44 PM
Brake cleaner is a solvent and so will include burnable chemicals which will alter the idler if you have an air leak.
AI is a poor substitute for asking on a forum. Most answers are gleaned from trawling the web for typical answers .. answers which are often wrong but don't have anyone to correct or update them!
Posted 10 September 2026 - 04:07 PM
I did have a thought however. When I put fuel in the turn the car over originally I used E10 as it was all the local had at that time. I know it's not good but thought one can isn't going to degrade the parts and would do until I can fill the tank. I just remembered that I used E10 and wonder if the burning capability may be causing the issue? Had a little look and it can cause a lean mixture and potentially boiling.
Posted 15 September 2026 - 12:44 PM
Mini Technical Sections →
Problems, Questions and Technical →
Car Shutting Off At Random, Ignition Wiring Burning HotStarted by oser1ww , Yesterday, 04:17 PM |
Smith Temp Gauge ModificationStarted by oldman1001 , 06 Oct 2026 |
Clutch Disengagement Issue - Cosworth Bda MiniStarted by cooperbloke , 01 Oct 2026 |
12G202 On A 998Started by Mini30BVA , 28 Sep 2026 |
Stuck Exhaust ValveStarted by JimmyStinkpickle , 28 Jul 2026 |
