that's without a doubt the single most offputting exhaust i've ever seen.
True - but from a technical viewpoint (as in, how he made & fitted it) it's pretty impressive!
Posted 22 May 2009 - 10:52 AM
Posted 22 May 2009 - 10:55 AM
Posted 22 May 2009 - 11:16 AM
Edited by mini_turbo_pete, 22 May 2009 - 11:17 AM.
Posted 22 May 2009 - 12:22 PM
Here's mine...
Posted 22 May 2009 - 08:36 PM
Posted 22 May 2009 - 08:37 PM
Posted 22 May 2009 - 08:42 PM
Here's mine...
Posted 22 May 2009 - 08:45 PM
Just so people know, if you have a 2" exhaust system on a 998 you WILL have less power compared to a 998 that has the correct size exhaust system. Theory has been tested and proved many times over, the 998's lose back pressure when a 2" system is fitted. The size of the tailpipe doesnt really matter (as long as its not ridiculously big) the important size is the bore of the manifold, link pipe and back box where it connects to the link pipe.
This also applies to using LCB manifolds on 998's. Use a Maniflow Cooper Freeflow manifold and the correct size exhaust sytem to fit to it and then have a rolling road session if you want to optimise performance. Minispares include all this in their Stage One Kit for 998s, (which you might has well have bought once youve bought the manifold and exhaust seperately) Most other companies will chuck in an LCB with their Stage One Kits, beware!
With a 2" system on a 998, yes it will be very loud, but you wont be going as fast as you could be. Use the correct size and just run a single box system, this will be just as loud
Posted 22 May 2009 - 09:13 PM
Posted 22 May 2009 - 09:36 PM
Edited by camp freddy, 22 May 2009 - 09:37 PM.
Posted 22 May 2009 - 10:11 PM
Heres a couple of pics of Ratty's exhaust, it's a modified DTM silencer, with modded
center pipe coming out of the sill..
can't wait to hear what it sounds like!!
Posted 22 May 2009 - 10:40 PM
Posted 23 May 2009 - 12:14 PM
Posted 23 May 2009 - 12:55 PM
While we're talking exhausts...
A few people have mentioned decatting...
If you do this, doesn't the MOT still include the cat level test based on the age of the car?
So what - do people just remember to stick the cat back in at the right time - or adjust the mixture sufficiently??
What happens if you get pulled over inside the London low Emission Green Zone and they do a check?
Posted 23 May 2009 - 01:29 PM
