The Real Mini Project
#286
Posted 06 March 2009 - 01:12 PM
#287
Posted 06 March 2009 - 01:30 PM
Will you need to put on a return fuel line like the spi/mpi? and if so, will you need a spi/mpi tank??
I'm thinking of putting a supercharger on my 1330 in the long run, and this is the only question i can't find an answer too !!
#288
Posted 06 March 2009 - 06:30 PM
nice work mate
i'm assuming you'll need to put a fuel pump and regulator on to your fuel lines.
Not sure what I totally need at the moment, just going to see how it goes, its only going on a standard engine at the moment so it should be fine, its when it comes to the rebuild the expensive item come in
#289
Posted 07 March 2009 - 06:09 PM
Got some stone chip stuff, gasket stuff and some loctite, and got two bolts from work for the exhaust, which I havn't used
And I had decided to give the subframe some coating while the exhaust was off, but it turned out to be a much harder job than I thought
Edited by 1987_ParkLane, 07 March 2009 - 06:12 PM.
#290
Posted 07 March 2009 - 06:28 PM
Will find some good place to stick them
Then I thought I would get the exhaust back on today, started off buy trying to drill the holes in the subframe for it to bolt into, only to find after about 45 minutes of trying, the drill bit was blunt
And here is how it sits:
But that is no where near completion yet
Only to find that I couldn't get it in assembled
So we put the head back on, and got the manifold bolted onto that, then tightened everything back up and it looks and fits great no
So a big thanks to my Dad
Then while I was looking at the finished piece, I realised the rear valance it not level (You can see it a bit in the last picture), so when its back on the road I might get it done and replaced, but not sure yet.
#291
Posted 07 March 2009 - 06:33 PM
how'd you get the free stickers you sod?
#292
Posted 07 March 2009 - 06:35 PM
Very nice!
Thanks, a very nice, persuasive email
#293
Posted 07 March 2009 - 07:15 PM
#294
Posted 07 March 2009 - 11:00 PM
I admire your patience, I'd have kicked
Manifold looks sexual
#295
Posted 07 March 2009 - 11:01 PM
#296
Posted 08 March 2009 - 12:05 PM
Exhaust looks great now.
I admire your patience, I'd have kickedout of the car if it was mine lol.
I bet the driveshaft was rubbing on the exhaust from when the engine mount went and the engine slid foreward lol.
Yer and also it broke that little bracket that goes onto the manifold and connects to the gearbox, which keeps it away from the driveshaft lol, but should be all good now
#297
Posted 08 March 2009 - 12:25 PM
So I started with the inside, and here is how it looked to start off with:
And here is how it ended up:
Then here is how the boot looked before:
And after:
So hopefully doing this will stop and rust and stuff if the floors or boot get wet. Just a few more things on the inside to do.
#298
Posted 08 March 2009 - 12:27 PM
#299
Posted 08 March 2009 - 12:29 PM
Looks smart mate, all that aggression paid off!
Yes it did
Edited by 1987_ParkLane, 08 March 2009 - 12:31 PM.
#300
Posted 08 March 2009 - 12:42 PM
