1293 Supercharged?
49 replies to this topic
#46 THE STIG
THE STIG
    Da stig says, GO GO GO
  • 2,506 posts
Posted 27 May 2009 - 05:09 PM
Has anyone used magajolt with a charger setup? I'm interested in doing this but was wondering about the crank pully?
Just to clarify, as i'm not familiar with this, what is megajolt?
programable ignition ecu
meagsquirt does injection and ignition
ah i see. Can it be used on carb'd mini's or just spi/ mpi?
well seeing as it replaces the dizzy can be used on enay engine goolge megajolt
#47 Surfbluegarage
Surfbluegarage
    AKA mini_mad_daps
  • 1,547 posts
Posted 27 May 2009 - 05:14 PM
theres two types that you can run MAP (manifold absolute preasure) or TPS (throttle position sensor) map is more commonly used on charged engines and still runs a vacumn like your advance on your dizzy does where as tps grub screws onto your butterfly on your carb.
#48 minicityE-2008
minicityE-2008
  • 488 posts
Posted 27 May 2009 - 05:15 PM
I'm just about to start building my 1293 engine now. I wont be able to afford a supercharger for a while. Is it possible to build it to the right lower compression and still run ok? Or will it run like a dog until i put the blower on?
Tom
Question bump
#49 THE STIG
THE STIG
  • 2,506 posts
Posted 27 May 2009 - 05:23 PM
Tom
Question bump
will still run just have less power than a high comprsion engine
many turbo engines out there that have just had turbos removed and still running around
some factry engines on run 8.9 9.2 any way so wont be that much lower
if you lowering your compression by doing work on the chambers in the head then just run a diierant head with less cc's till put on charger then fit head with more cc's and lower compresstion
#50 minicityE-2008
minicityE-2008
  • 488 posts
Posted 27 May 2009 - 05:30 PM
Tom
Question bump
Ok, thank you for that :dontgetit: Thats all i needed to know
