1293 Supercharged?
#31
Posted 10 May 2009 - 06:30 PM
#32
Posted 15 May 2009 - 06:32 PM
I have sent you a PM with contact details - I have what you are looking for if you fancy a ride. I'm only in Bagshot and would only be to happy to take you for a spin.
James
#33
Posted 22 May 2009 - 06:18 PM
Also i would be selling the manifolds for aorund the £175 -£200 mark to see how well the sell and will also be makin the intake pipe to suit but as far as im aware ones that are out there will fit...
#34
Posted 22 May 2009 - 06:59 PM
Tom
#35
Posted 22 May 2009 - 08:29 PM
i have the 1293 already but the head is stripped off,
i dont know if i should get the head sorted to make it lower compression or get a decompression plate
i need to do more research
#36
Posted 22 May 2009 - 10:09 PM
im planning on doing the exact same thing
From what i've researched it seems its better to have the head work done as a decompression plate is a kind of "quick fix" solution. However it would seem that from the people i have spoken to with decomp plates haven't had any trouble with it. I guess it's down to what you can afford. But i'm no expert.
#37
Posted 24 May 2009 - 03:26 PM
#38
Posted 24 May 2009 - 08:38 PM
#39
Posted 25 May 2009 - 06:09 PM
#40
Posted 26 May 2009 - 09:45 AM
#41
Posted 26 May 2009 - 03:05 PM
#42
Posted 27 May 2009 - 11:10 AM
Performance was excellent about 25% more power and very tractable.
Mine was an old Shorrocks kit, quite difficult to fit in, if you are using a modern kit I guess it will be easier.
Don't use a 'wild cam' - high lift rockers are good.
Get your distributor recalibrated to suit
Make sure your cooling system is in good order
#43
Posted 27 May 2009 - 03:50 PM
Has anyone used magajolt with a charger setup? I'm interested in doing this but was wondering about the crank pully?
Just to clarify, as i'm not familiar with this, what is megajolt?
#44
Posted 27 May 2009 - 04:10 PM
programable ignition ecu
meagsquirt does injection and ignition
#45
Posted 27 May 2009 - 04:56 PM
ah i see. Can it be used on carb'd mini's or just spi/ mpi?
