What Engine Conversion
121 replies to this topic
#31 rosco454
rosco454
  • 908 posts
Posted 04 May 2009 - 10:05 PM
The redtop is the 16v xe version of the 2.0 vauxhall.The 8v is just normally known as the 8v.
Meant to put that in the pm but forgot about it :thumbsup:
Edited by rosco454, 04 May 2009 - 10:08 PM.
#32 Liam-Taylor
Liam-Taylor
  • 55 posts
Posted 04 May 2009 - 10:09 PM
oh ok cheers ross
also so far i have seen alot more 16v cars, i also would get the clubman to do the 16v if i had to
Edited by Liam-Taylor, 04 May 2009 - 10:19 PM.
#33 Liam-Taylor
Liam-Taylor
  • 55 posts
Posted 05 May 2009 - 03:15 PM
right for now it depends qhat mini i get if i get the round nose it will be the 8v and if iu get a clubman it will be a 16v
also there are loads of redtops for sale going well cheap just can't find the 8v really
would i need this and do the light bits just come out
http://www.absmotors...ont-p-4889.html
Edited by Liam-Taylor, 05 May 2009 - 04:23 PM.
#34 Liam-Taylor
Liam-Taylor
  • 55 posts
Posted 05 May 2009 - 06:30 PM
bump
#35 Liam-Taylor
Liam-Taylor
  • 55 posts
Posted 06 May 2009 - 03:54 PM
anyone else also what exhaust do you lot reccomend also quite loud
Edited by Liam-Taylor, 06 May 2009 - 03:54 PM.
#36 1293sleeper
1293sleeper
  • 805 posts
Posted 06 May 2009 - 04:00 PM
i've said it before ansd i'll say it again mid mounted impreza wrx using the 1.8fwd box would make an amazing mini.
#37 Liam-Taylor
Liam-Taylor
  • 55 posts
Posted 06 May 2009 - 06:27 PM
that would be well good but if i had the money i would love to put an evo in it
#38 Liam-Taylor
Liam-Taylor
  • 55 posts
Posted 07 May 2009 - 05:07 PM
also 1293sleeper what kind of bhp would that be running
#39 Liam-Taylor
Liam-Taylor
  • 55 posts
Posted 07 May 2009 - 09:41 PM
anyone help me about exhausts
#40 Geehawk
Geehawk
  • 500 posts
Posted 08 May 2009 - 06:30 AM
Why worry about exhausts, thats a long way down the line. :thumbsup:
#41 maph2
maph2
  • 1,291 posts
  • Local Club: Poor Boys Warwick
Posted 08 May 2009 - 09:28 AM
ROFL - exactly, plenty of other stuff to worry about first
things to bear in mind - redtops are heavy engines (vtecs slightly less) but make more torque than their equivalent vtecs.
alos i notice that some people have said that the 16. 16v gm engine has to go on Tb's - not true. allspeed with reverse the inlet manifold to allow it to fir, thefore keep the stock ecu etc. bear in mind you may well need to move the brake/clutch cylinders inside the car.
also, you have to be very clever to fit a redtop under a standard length roundnose
can you fabricate/weld. if so you'll be fine. if not, i'd learn asap.
and if you go with the watsons set up, be aware that is a metro frame so you loose the mini handling.
ps i have a redtop on TB's so have some knowledge of these things
#42 bingobango
bingobango
  • 140 posts
Posted 08 May 2009 - 09:47 AM
just go r1 and be done with it.
#43 maph2
maph2
  • 1,291 posts
Posted 08 May 2009 - 10:57 AM
LOL, cause it that simple......no reverse or hearing as you have to rev its tits off to move......
Edited by maph2, 08 May 2009 - 11:16 AM.
#44 Lenny.G
Lenny.G
  • 30 posts
Posted 08 May 2009 - 11:13 AM
Maph - havent you built one of these minis? How much did it cost? Just wondering as you could give him an idea of cost, IF you fabricate your own parts?
I did notice that OP is only 15 also, so whilst considering your engine conversion have you also considered how you propose to insure a 2.0l??
#45 maph2
maph2
  • 1,291 posts
Posted 08 May 2009 - 11:20 AM
"But in the end - even a 190BHP Mini isn't the fastest thing in the world and still can't eat Porsches for breakfast (but at least giving them a hard time :thumbsup:)..."
erm, have you been in a hybrid mini....off the line....M3's get seen off easily. 190 bhp in a 600kg car plus superior handling will give bloody nose to beetles and other more "powerful" machinery. depends what track you are on
