Push Button Starter?
96 replies to this topic
#61 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 22 April 2006 - 04:19 PM
I started this thread about 6 months ago and still aint done the work! :proud: LMAO
#62 Cookie Monster
Cookie Monster
  • 244 posts
Posted 22 April 2006 - 10:28 PM
You realy ought to, took me all of 10 mins to rig both of mine LOL
#63 * Specialized *
* Specialized *
  • 656 posts
Posted 24 April 2006 - 05:04 PM
i was just wondering , i am thinking of putting savage switches in my switch panel, can they be mounted flush,
#64 syholl
syholl
  • 710 posts
Posted 24 April 2006 - 08:20 PM
Yeah, they can be flush mounted, or recessed ever so slightly like i did in my van....
Attached File  _l5i5810.jpg   41.99K   59 downloads
#65 * Specialized *
* Specialized *
  • 656 posts
Posted 24 April 2006 - 09:51 PM
looks awesome, just love momo, i want to put them in my switch panel, but dont know where to start, can u help? cheers Joe
#66 syholl
syholl
  • 710 posts
Posted 25 April 2006 - 06:26 AM
If you are replacing the existing switches, you will need to modify the indicator/hazard circuit quite a bit. as the standard Mini hazard switch has a lot of terminals that the savage type don't.
The savage type switches are basically on or off, but they do have the option of push-to-make, and push-to-break at the same time, meaning you can power both the hazard and indicator circuits from the same fuse and when the hazard switch is operated, it disconnects the indicator circuits.... You will also need to get some diodes to use in the hazard circuit.
If you do a google, you will be able to find some more circuit info, but here is one i just found that should start you off
http://www.uk-hotrod...ics/Harzard.htm
As for light switch, you will need 2, one for the sidelights and one for the headlights. Brake test switch can be done easily enough, and so can the rear demist...
#67 * Specialized *
* Specialized *
  • 656 posts
Posted 25 April 2006 - 01:14 PM
thats great thanx syholl, my dad will probs do it as i dont know much about the electrics and that, thanx again
#68 Cookie Monster
Cookie Monster
  • 244 posts
Posted 27 April 2006 - 06:40 AM
Just received my savage start switch, unfortunately it has got to go back as the face is damaged.
Any way question is - can these be wired straight into the start circuit or is an additional relay needed, it is just that the switch block supplied looks a little flimsy
#69 syholl
syholl
  • 710 posts
Posted 27 April 2006 - 07:08 AM
The savage switches have a built in relay, these are rated at 10 Amps if i remember correctly (It might me 20, but it should tell you in the instructions...).
Anyway, i only fitted an extra relay on the main beam on mine, the starter and headlights are fine straight through the switch...
#70 Cookie Monster
Cookie Monster
  • 244 posts
Posted 27 April 2006 - 07:45 AM
Cheers Syholl
Thats a big help, it's just that the little switch/relay block they supply doesn't look ig enough. Going to be leavling the main beam on the stalk so should be OK.
Mark
#71 Big Sam
Big Sam
  • 853 posts
Posted 24 May 2006 - 07:07 PM
Ive started the arduious task of trying to par up the renault laguna keyless entry system, then starter button, its a pain to say the least but in the end it will be worth it because ive yet to see anyone with it.
#72 pikey7
pikey7
  • 3,824 posts
Posted 24 May 2006 - 08:22 PM
sounds like a fun project Sam! ;D keep us updated.
#73 nosboy83
nosboy83
  • 235 posts
Posted 25 May 2006 - 09:11 AM
I wnat one of these!
Fitted to honda s2000. NICE!!!
Honda sell those for £20 iirc
#74 PhoenixSimon
PhoenixSimon
  • 1,050 posts
  • Local Club: BOGMOC
Posted 27 May 2006 - 08:11 AM
im wanting to put a push button start in mine and fancy one of these, looks pretty good and comes with all the bits to wire up.
http://cgi.ebay.co.u...Y_BIN_Stores_IT
Simon
the guy says he will do 3 for the price of 2 and you only pay one lot of postage, thats 3 for £35, if anyone is close to me im on for a group buy!
#75 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 27 May 2006 - 10:17 AM
I know they look the business, but once you've fitted it and turned the key two clicks, won't you just carry on turning once you get lazy?
I imagine it would be more useful if it had a kill switch to partner it then you could stop and restart the engine without messing with a key.
Still cool tho.
