My Mini City
219 replies to this topic
#76 CAU998
CAU998
  • 1,202 posts
  • Local Club: TMF South Central...
Posted 13 November 2005 - 11:23 PM
Finally got heater and hoses out. Ive also disconnected the dash switches choke cable etc. Started to disconnect the gear linkage, what a pain in the arse. Knocked pin through just cant pull the bolt through :w00t: ! Taken front wheels off, can't believe how clogged up the discs are. Looks like its bin off road a few times to say the least lol. :tongue: Ill post up some pics tommorow.
#77 CAU998
CAU998
  • 1,202 posts
Posted 14 November 2005 - 05:14 PM
Heres the pictures...
#78 CAU998
CAU998
  • 1,202 posts
Posted 14 November 2005 - 05:15 PM
#79 CAU998
CAU998
  • 1,202 posts
#80 CAU998
CAU998
  • 1,202 posts
Posted 14 November 2005 - 05:16 PM
#81 CAU998
CAU998
  • 1,202 posts
Posted 14 November 2005 - 05:21 PM
The bolt thats causin all the hastle :w00t: ! The only bit left till the gear linkage can come off. Its the bolt nearest the gearbox on the gear linkage stabiliser. Then its just splitin the ball-joints, pulling the driveshafts out of the gearbox and undoin the engine from the car. Then it can come out finally! :tongue:
#82 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 14 November 2005 - 05:38 PM
I am guessing the bolt is seized in the hole then? Have you tried a load of WD40 and then turning the bolt with a spanner/ratchet to free it up?
#83 CAU998
CAU998
  • 1,202 posts
Posted 14 November 2005 - 06:00 PM
no the bolt does move it just doesnt pull through the gear linkage stabiliser bracket.
#84 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 14 November 2005 - 06:02 PM
Aaah, so it must have worn a ridge in somewhere. I would guess it will be a case of elbow grease then I'm afraid. Unless you could cut the head off the bolt and knock it through the other way??
#85 CAU998
CAU998
  • 1,202 posts
Posted 14 November 2005 - 06:37 PM
yeah im gonna try mole-grips and then maybe i will resort to that :erm: its so annoying.
#86 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 14 November 2005 - 06:48 PM
yeah, there's usually one bolt on every job that is a pig! Even if you only have one to undo! lol
#87 CAU998
CAU998
  • 1,202 posts
Posted 14 November 2005 - 06:50 PM
i know thats the case with everything on a mini lol :grin: !
#88 CAU998
CAU998
  • 1,202 posts
Posted 14 November 2005 - 09:49 PM
what do you think of this? Its a KAD gearbox rear mounting. Should i get one or not and if i do ill also get the matching engine steadies.
#89 CAU998
CAU998
  • 1,202 posts
Posted 14 November 2005 - 09:56 PM
For christmas my parents have asked do i want wheels, interior or the above and other goodies including KAD quickshift, drilled and grooved discs with pads, K&N airfilter, maybe an exhaust (Playmini Carbon-Tec). So what should i get? because im unsure what to do.
#90 CAU998
CAU998
  • 1,202 posts
Posted 14 November 2005 - 10:01 PM
This is the interior but it would be white piping rather than red to match the colour scheme of my car.
