Impressive work! I have been thinking of doing the same wooferbox but with one 8inch on each side. Time will tell.. keep it up!
Fern...
#211
Posted 10 March 2014 - 08:01 PM
#212
Posted 22 March 2014 - 08:22 PM
Finally, after sooooo long, some progress.
I got into the garage for about an hour today & re-braced the parcel shelf to the spit so I can remove the wheel arch without taking the whole car off the spit. Then I set about removing the arch, I ground through the seam until it prupled & pealed off which split the two panels then made a start on the inner seam. My spot weld drill went straight thru both sheets of metal as I couldn't make out the difference so I've decided to use the same method as the outside seam & just grind through it until they separate. I'll need to repair some of the lip once the arch is removed but that's not a problem.
#213
Posted 27 March 2014 - 06:38 AM
Finally got the wheel arch removed, had to take it out in 3 pieces in the end as I couldn't see the spot welds for the bracket, seat back or rear bin so chopped it down til I could grind through & remove it.
Once I've rebuilt the edge lip properly I was thinking of tinning & lead loading the seam around the arch & closing panel area to hopefully reduce any future rusting. I'll be starting on the back of the rear quarter panel as there is a hole & then move on to chopping out the previous bodge of a boot floor at the back. Slowly, but progressing still.
Edited by Brams96, 27 March 2014 - 06:43 AM.
#214
Posted 27 March 2014 - 08:23 AM
I find little and often is the way forward
#215
Posted 27 March 2014 - 01:56 PM
Yip, that's what I'll be doing ;) I've got to order some new genuine parts now too after my mate pointed out the bit's I'll need, gonna be about £250 :-( I never realised the arches were so expensive.
#216
Posted 29 March 2014 - 06:47 AM
#217
Posted 29 March 2014 - 06:46 PM
Mine were all the way through, and there are several layers of metal there!
Can a man of your calibre not fabricate rear arches?
#218
Posted 31 March 2014 - 05:25 PM
I'll be trying to do as much as I can over the next few days/week as I'm on nights so can get the grinder out without disturbing the neighbours.
I've also got the Volvo to do a bit of work on, I need to repaint the top of the boot above the window to get rid of the scratches, weather dependant of course.
