Fern...
#16
Posted 10 October 2009 - 07:02 PM
#17
Posted 12 October 2009 - 09:21 AM
The next thing on the list will be the doors. Sound mat on the inside of the outer skin then MDF pieces glued into the holes to create a sealed enclosure then I'll cut a hole behind where the door speaker pod will go. Should sound really good as I have done this in the past with good results.
Note to self: Make sure i put the central locking in first!
#18
Posted 13 October 2009 - 11:42 PM
Edited by Brams96, 16 October 2009 - 12:47 AM.
#19
Posted 14 October 2009 - 06:00 PM
While under there I decided to see what was banging when I put my foot on then off the accelerator. I found the exhaust mounting bracket from the dif housing broken into 3 pieces! Luckily I had another from the other gearbox so I swapped them then went for a drive. Surprise surprise, no more knocking and it actually feels smoother accelerating and decelerating with the brace on now. Thats 1 less thing to do, sweet
Exhaust bracket:
Edited by Brams96, 20 October 2009 - 12:25 PM.
#20
Posted 16 October 2009 - 12:47 AM
The HIF44 carb from the Metro Auto is now all clean and I also have the HS4 back together. I had forgotten how it all went back together so had to trial fit everything until I figured it out. The return spring was the biggest problem, trying to figure out where it attached to to make the arm return properly. All I need now is some new gaskets for the HIF and to paint the bell and it's ready to fit.
I also masked up the rear passenger bin today. I used cardboard to make a small gap on the outer panel so it gives enough clearance for the sound mat that will be going there. It took about an hour to cut all the cardboard and half a roll of tape. Tomorrow I will start fiberglassing the outside enclosure & once I have a mould I can remove it and strengthen it.
#21
Posted 16 October 2009 - 06:03 PM
#22
Posted 17 October 2009 - 07:02 PM
Edited by Brams96, 20 October 2009 - 12:30 PM.
#23
Posted 17 October 2009 - 10:39 PM
#24
Posted 18 October 2009 - 07:11 PM
I also started on the fiberglassing of the sub box using the donor car as a template. Hopefully the mould will come off the masking tape without too much trouble. Once it comes off I can strengthen the inside and trial fit it to Fern. I'm contemplating using a metal bar accross the back to make it more rigid and stop and flexing there might be as that side will be directly opposite the back of the sub and id quite a large single piece. I must take some pics and put them up.
I finished polishing the 3rd conrod and started on the 4th last night so will try to do more on them tonight.
Here's a cople of pics of the roof.
#25
Posted 18 October 2009 - 10:08 PM
#26
Posted 19 October 2009 - 11:12 PM
I've left the roof for now to dry another day and will remove the supports tomorrow at some stage, fingers crossed it will be ok otherwise I'll be pulling it all down and starting again. It should be Ok.
I recieved the LED ultra bright lights today and tried them straight on an old battery & . . . COOL! I then tried them inside a rear light lense with good results. I think I will use them for the indicators as they will quite easily fit inside the lenses and are brighter than the normal bulbs. Again Pic will be posted as I go.
#27
Posted 20 October 2009 - 12:35 PM
Edited by Brams96, 20 October 2009 - 12:36 PM.
#28
Posted 20 October 2009 - 12:41 PM
Posted 21 October 2009 - 09:04 PM
I've also made the front of the box where the sub will fit, I actually did this first as I need to see where other parts would fit. I had to cut a 4-5" line down part of the metal outside of the bin but nothing to drastic. I have a feeling I might need to make as much of the box as possible and then build the rest in place in the car. The top near the window is going to be a 'challange' as that is where it will secure to the body, I have a rough idea of what I will do but I'll have to see how everything turns out.
If any one is interested in the dimensions to build their own then just let me know and I will do a diagram with all the measurements. Baring in mind I am planning on putting a very shallow sub in this box. I'm going to use a Sony XS-L10S driven with about 250-300Wrms.
Edited by Brams96, 22 October 2009 - 07:48 PM.
#30
Posted 22 October 2009 - 08:00 PM
I somehow need to work out the volume too. I thought putting a couple of sealed plastic bags in and filling them wit a measured amount of water might do the trick. I'll think about that one.
One semi-major thing I will have to do is modify the back of the rear seat as the piece that goes over the wheel arch no longer can do that. The base is fine, just a little tighter than it was before. It should be just a case of cutting the piece out and welding the bars back together to form a straight line and hopefully just reclipping the upholstery behind it, I dont really want to have to pay to get them retrimmed at this stage. Both sides will need doing as the drivers side will probably house the amp but not sure yet it might end up in the boot.
Enough rambling here are some pics.
You might be able to see in the fourth pic the circles I drew on the box, the largest is actually 12" soI might even be able to fit in a 12" if it is the same depth. That would be cool!
Edited by Brams96, 22 October 2009 - 08:02 PM.
