Fern...
#91
Posted 23 April 2010 - 07:05 PM
#92
Posted 27 April 2010 - 08:12 PM
#93
Posted 27 April 2010 - 08:25 PM
#94
Posted 29 April 2010 - 06:57 PM
So far i have run in all the speaker cables for the front doors from the amp to the doors, made and mounted the amp back board and wired in the amp, run all the power and earth cables, run all the RCA's, installed a new carpet underlay, installed a smiths water temp gauge, installed my hand made switch panel (see the picture), made up and covered a partial dash cut off and remounted the bonnet brackets, painted the inside of the bonnet and fixed the problem with the carb.
Here are a couple of pictures so far:
The bonnet minus the old brackets:
The new brackets fiberglassed in place. I used tread plate because the 5mm aluminium plate I used first wouldn't bend without breaking:
The 3mm Blue Perspex switch panel. I have LEDs behind it so it should light up qite well at night:
I didn't want to muck around with a full dash install with everything else I have to do so I thought I would just make a partial dash big enough for the radio and 2 gauges (Water Temp and Oil Pressure). I've covered it all now and have it in place, anyway here's the result:
Over the next few night shifts I will be finishing off the wheels and sub box. No pressure but only 15 days to get it all done!
#95
Posted 30 April 2010 - 05:43 PM
Painted one wheel last night with high build primer and will be doing the last one tonight then I can colour coat all 4 wheels before 3-4 layers of laquer.
#96
Posted 02 May 2010 - 05:39 PM
Edited by Brams96, 02 May 2010 - 05:44 PM.
#97
Posted 09 May 2010 - 08:26 AM
One layer of t-shirt material to get the shape and first layer of fiberglass matting
First smoothed layer of filler for shaping
Second layer of filler being smoothed off by the wife with the 'help' of our dogs
Finished off in Acoustic carpet spray glued into shape.
In place. It is slightly tighter than I would like and doesn't sit as low as before the fiberglass went on but I can fix that with a grinder
Dash at the moment as I'm still fitting all the wiring for the new radio and dials.
Switch Panel lighting. It s a bit hard to see but looks pretty cool.
Wheels all painted and with rubber on (small scratch where the clamp was will be retouched)
Thats it for now.
Edited by Brams96, 09 May 2010 - 08:31 AM.
#98
Posted 10 May 2010 - 08:26 PM
#99
Posted 10 May 2010 - 09:48 PM
#100
Posted 11 May 2010 - 07:58 AM
#101
Posted 12 May 2010 - 11:09 AM
So far I have got the 1/2 dash in, radio installed and working, sub box sitting in the bin properly now and wired up, all the interior back in, bonnet fitted (as best it can) and 2 wheels laquered. Just recieved my delivery from Minispares this morning of wheel nuts, centre caps and all bonnet rubbers so that will all be getting put on tonight. Hopefully tomorrow I can get the passenger door off and the gromets and wiring done to the doors then all I have to do is install the front speakers and set the sounds up. Yay, it's finally coming together.
I'll post more pictures when I get them.
#102
Posted 13 May 2010 - 07:07 AM
The Sub box in place and fitted properly. I had to grind about 5 - 10mm from the top lip of the bin.
The wheels finally on. The rear is sitting a bit high so I guess a set of Hi Lo's is next on the purchase list
The bonnet now with buffers and a strap. It still needs a coat of polish which will be happening Saturday morning .
I still need to fit the rubber seal at the back of the bonnet but I'm not quite sure about where I am supposed to cut ti to get the right angle
#103
Posted 13 May 2010 - 07:43 PM
#104
Posted 17 May 2010 - 10:04 PM
Kentish Mini Owners Club contingent
Parked at Crystal Palace
Back Home after the run.
Edited by Brams96, 17 May 2010 - 10:23 PM.
#105
Posted 17 May 2010 - 10:27 PM
Edited by MiniJosh92, 17 May 2010 - 10:28 PM.
