Edited by cbyrne, 11 August 2009 - 10:18 AM.
1275 Spi
Posted 11 August 2009 - 10:17 AM
Posted 11 August 2009 - 10:34 AM
Posted 11 August 2009 - 10:48 AM
Posted 11 August 2009 - 10:53 AM
Even thou that ecu isnt re-mappable, i think someone on here had a crack with it.
Posted 11 August 2009 - 11:01 AM
Posted 11 August 2009 - 06:13 PM
i was looking at a fast road/rally cam but intend on building the engine a little first was told to remove the L bracket on the throttle body it allowes the butter fly to open more so more air flow but i have not herd of any one doing this??
There is no 'L' bracket to remove on the SPi. The throttle opens fully as it is.
Posted 11 August 2009 - 09:34 PM
Posted 11 August 2009 - 10:04 PM
would a stage 3 head with 1.5.1 roller rockers be a bit much?
A bit much for what?
Posted 12 August 2009 - 08:18 PM
Posted 12 August 2009 - 08:41 PM
mine had an L bracket, i bent it out the way and it didnt work as the throttle went too fat over and locked itself on lol, only thing to do is saw it thinner so it will open slightly more and not jam on.
when you take the air filter off you can see that the body dosnt open anywhere near full as standard!
Posted 12 August 2009 - 09:35 PM
Posted 12 August 2009 - 09:43 PM
Are we talking spi or mpi, as I can asure you the throttle opens fully on the spi without modification
i can asure you it dosnt and if i remember ill take a picture of it to show you my cut down L braket, and even down the bore of the body to show its still dosnt open quite fully.
Edited by rick.spi, 12 August 2009 - 09:43 PM.
Posted 13 August 2009 - 02:36 PM
Edited by cbyrne, 13 August 2009 - 02:37 PM.
Posted 13 August 2009 - 06:16 PM
You can clearly see that the throttle opens fully without any modification to any bracket
I would be interested to see your pictures
Posted 14 August 2009 - 07:59 AM
