Can't put the front subby on as ive lost the you bolts for the steering rack, so need to order some more.
Stripped the flitch panel and remainder of inner wings, and stonechipped them, as well as removed the doors
Then today i made a start on making my seat mounts.
Started off by removing the original handbrake brackets then cut the first bit of tubing to length and tacked it in
Needed to make a little support for the middle as there was a gap
Cut the second bit of tubing and tacked that in, with a support in the middle again
Then fully welded each end and the supports, and then drilled the holes for the driver seat
Bolted her in and couldn't resist a little test run
Tomorrow i'll bolt the passenger seat in, and make some new mounts for the handbrake
