So if I buy a genuine scuttle with the lip up how will this be welded on etc?
Posted 18 October 2009 - 09:04 PM
Posted 18 October 2009 - 09:18 PM
Posted 18 October 2009 - 09:39 PM
You need something to weld the new scuttle onto first!!
You can see daylight though it, that means the inner flitch is shot as well.
The window lip that the scuttle attaches to will also need considerable work as well.
Posted 18 October 2009 - 09:47 PM
Posted 18 October 2009 - 09:50 PM
Edited by shiftyseamus, 18 October 2009 - 09:54 PM.
Posted 18 October 2009 - 09:57 PM
Posted 18 October 2009 - 10:00 PM
You may hate me for saying this, but do you really know what your taking on with this car? Its a pretty much a basket case and will need a shed load more work than I think you realise.
I've seen the pictures and you're looking at a panel bill of £700-£1000 just to get it sound and solid again, not to mention the hundreds of hours welding.
It may be better to find a less ripe car to restore.
Posted 18 October 2009 - 10:02 PM
You can get genuine panels from here....................
http://www.bmh-ltd.com/
.....................good luck...................
Posted 18 October 2009 - 10:11 PM
Well yeah I suppose but I dont know how you work it out at £700
Its not like I need it done any time soon so hundreds of hours are ok
Posted 18 October 2009 - 10:17 PM
Trust me, I ve done enough of em to know how much they cost!!
Pair of floors - £100x2 - These arent £100 I got the right front and rear and inner sill for like £30
scuttle - £100 - On minispares even an original scuttle is £30 approx
Wings - £35x2 - Dont think I need wings
Front panel - £50 - Or front panel
A-panels £10x2 - Only need one of these
Rear 1/4 £35 x2 - Dont need these??
Boot floor - £25 - Dont need this just 10" repair strip which is like £20
Lower boot hinge £75 - ?
Door steps - £15 - ?
Crossmember - £55 - Can patch this
Valence - £10 - Yeah need this
Valence stiffeners - £15x2 - ?
Heelboard - £100 - ??????
Subframe closing plates - £10x2 - ????????
Inner sill stiffeners - £15x2 - ?????
Door skins - £25x2 - Need one of these
Boor floor corners - £15x2 - Need these but im sure the are cheaper
Flitch panel - £10.35x2
I'm not sure how much the full flitches are, also depends on the state of the toeboard, Which Is??
Thats just for starters!!
Theres also companion bins ( Could I not plate this) , front shock mounts (??) and rear wheel arches. ( These are fine)
It soon adds up.
Posted 18 October 2009 - 10:25 PM
Posted 18 October 2009 - 10:31 PM
Fair enough, believe it or not I am actually trying to help you. I've done enough cars over the years to know what it take to do a 1/2 decent job of one. Regardless of what you think of my list that is what you'll need to do decent job on the car.
Posted 19 October 2009 - 01:55 PM
Posted 19 October 2009 - 02:56 PM
I, think what shifty is trying to say is that once you start removing panels to do the repairs you have spotted, you will end up buying pretty much all the panels on the list and you also can't always get away with the cheapest panels as some fit terribly.
derusting a mini works on the iceberg theory, theres a lot more under the surface
Mini's, you gotta love em
Posted 19 October 2009 - 02:58 PM
