Bad Lacquer Advice!
#16
Posted 26 October 2009 - 08:41 PM
Phil
#17
Posted 26 October 2009 - 08:44 PM
Ended up scraping it all off with a scraper and some thinners, Luckily it was only the Rear of the car I had painted.
#18
Posted 26 October 2009 - 08:46 PM
#19
Posted 26 October 2009 - 08:52 PM
I work in my friends bodyshop doing up my bike and cars - he's a professional sprayer - Ill ask his advice tomorrow - Im sure it will be similar to that above, but he might give you some more options.
Jon
#20
Posted 26 October 2009 - 09:29 PM
#21
Posted 26 October 2009 - 09:32 PM
#22
Posted 26 October 2009 - 10:52 PM
#23
Posted 26 October 2009 - 10:56 PM
If it's not hard, can it be kinda 'swept' off with something?
(Man I feel for you! Painting is the scariest bit of all for me - I HAVE NO IDEA, so don't take anything I say regarding paint as advice!)
#24
Posted 26 October 2009 - 11:00 PM
Edited by panelbeaterpeter, 26 October 2009 - 11:01 PM.
#25
Posted 27 October 2009 - 07:30 AM
#26
Posted 27 October 2009 - 11:05 AM
#27
Posted 27 October 2009 - 11:56 AM
#28
Posted 27 October 2009 - 12:39 PM
It is an acrylic type that does not need any additives, it is designed as a stop gap between cellulose and 2k, cellulose has an agressive base chemical that will react with 2k base coat, and 2k base coat will require a 2 parts lacquer to 1 part activator/hardener and approx 10% thinners. You will also need a finer nozzle spray gun to achieve a good result and a respirator.
This is the UPOL ready to use stuff...
If this is what you have used then your fine. 3 coats is fine and you will need to keep the garage heated over night for it to cure. You will probably find that it is the low temprature that is prolonging drying time.
A couple of fan heaters from Argos £12 each will do the trick..
#29
Posted 27 October 2009 - 12:44 PM
now my mini looks the texture of orange peel, it is also 3 days ago i sprayed it and its still not hardened properly (after readin the instructions it advises thinnig 2:1)!!!
HElp help help
Phil
Also as a note.. you have not thinned it, but you can get away with that , dont attack it with nitromorse. the thinners will do just that, "Thin the paint" as you missed that step, you will have thick pacquer and thats why it has orange peeled, and also because it is so thick, it will take longer to cure.
when it is dry, you can flat it back with some P1200 wet n dry and lots of soapy water, then move up to P1500, then to p2000 and buff it up to get a smooth glossy finish..
Hope this helps..
#30
