Total Rust Bucket 1977 Mini Clubman.
cookie4343
, Nov 15 2009 10:53 PM
52 replies to this topic
#46
Posted 07 April 2010 - 05:41 PM
Keep at it.
#47
Posted 07 April 2010 - 06:26 PM
that looks a simalar colour to max it also looks about as rotten as max to good work keep it up
#48
Posted 10 April 2010 - 07:46 PM
Done some more today, doesnt look much but wasnt the easiest job in the world.
picture of how i started.
Then my grinder decided to pack up
Lucky i have 2.
Then i cut a big hole.
Then i removed the door post panel.
Clean up all the surface rust and spayed with weld thrue primer.
Then i welded it in place, looks a mess but the grinder should sort it and i hope the door lines up otherwise my big hammer is comeing out.
Sprayed some black paint on the inner wing, i gatherd the more paint the better.
And how i finished, hopefully have the flitch welded in place tommorow.
Edited by cookie4343, 10 April 2010 - 07:46 PM.
#49
Posted 10 April 2010 - 08:04 PM
Only just noticed this thread Cookie, great to see another Clubby being rescued, you're a brave man taking it on but you're progress is looking fab
#50
Posted 10 April 2010 - 10:31 PM
Nice work
Although you might want to leave the final flinch panel welding till the door is in place (saves tears laters) as i've found the holes in the drivers side panles line up, but too far inboard on the panel. so you might find once the door is bolted up the flinch and a panle stick out further than the door does by quite a bit. Easy fix though, just file out the holes and move the flich panel inboard a bit more before welding.
#51
Posted 11 April 2010 - 07:10 PM
Cheers for the comments guys, keeps me going
Today i welded on the flitch.
First i derusted surrounding area's and weld thrue primed.
Tacked on.
Fully welded with some small repair patches.
Welds cleaned up abit
Thanks for looking and keep the comments comeing, cheers Tmf'ers.
Tacked on.
#52
Posted 11 April 2010 - 07:22 PM
Cheers for that mate, are you filling the air vents or not?
I should be doing mine next week
Oh by the way, the floor is in and I have updated my project thread
Good luck mate
Good luck mate
#53
Posted 14 April 2010 - 03:39 PM
Nice progress
Gonna be awesome when done!
Dave
Dave
